Anyone know security screwfor MAF sensor removing
As above, that size seems to be the only one not in my torx and lock screws set. cheers
That torx screw has a pin in side so you need a special bit for it not sure of its size sorry. If your changing the Maf You don't need to touch those torx screws . Cleaning a Maf has mixed results so I'd just buy a new one.
If desperate to remove use some long nose mole grip or pliars around it and remove. Or grind a line out of it for flat head screwdriver
DG
I picked up a set of Laser 5 point stars with security pin from my local Halfords.
As above 5 point security star bits ;-) i bought a set a few years ago... never been used :-(
I borrowed the tool to remove these stupid screws and replaced them with pozidrive head self-tappers. Idiot detail.
rotodiesel.
I have a similar set, but in a blue plastic case. I think the cost was around £10 and it has been very useful for coping with a variety of security fasteners on various electric appliances and even toys.
Just found this at Maplins:
http://www.maplin.co.uk/33-piece-security-bit-set-11520
spot on cheers guys, il buy a set. looks like i might just change maf, although its just to see if my mpg goes up
