06 TFSI VRS written off looking at 07- 170 CR VRS replacement
Our petrol octy vrs estate has bitten the bullet in a rta. We will be battling with the insurance company shortly for a payout and Im looking at a 07- 170 diesel vrs as a replacement.
What do I need to look out for on the diesels ,will an 07 be a CR engine or PD and how do I tell by looking or are they the same ?
cheers
Dave
Couldn't tell you the visual differences but for sure on an '07' it will be a PD.
2007 diesel vRS's will be PD's.
The CR was introduced during 2008.
You can tell a CR over a PD by looking at the plastic engine cover under the bonnet..
Edited by silver1011
You'll need to look under the lid to see the difference.
you'll probably know if you take it for a test drive too, boot it and if it has an allmighty thump in your back when the torque kicks in, its a PD.
If the torque seems more spread through the range it's a CR.
I like the sound of the pd ,reminds me of my old 5 gt turbo :rofl:
Thats great
cheers
Dave
As said a 2007 will be a PD170.
Common issues with the vRS, petrol or diesel are the ABS and the aircon.
Warranty/Re-call - Petrol will be coil packs and Diesel will be injectors.
And DPF's...
And the injectors on the PD170.
Personally I'd go for a PD140 non-VRS or CR170 and skip the PD170.
The injectors are a non-issue on the PD170 as they're being replaced FOC.
DPF removel and remap (if required/desired) can be done for £400.
The PD170 is a cracking engine.
That assumes the FoC replacement doesn't cause more problems such as the more common than it should be diesel in oil and associated turbo etc failures.
Very true, I experienced both, neither were particularly pleasant.
This was however through the incompetance of the dealer and not a reflection on the car.
Given a choice I'd likely chose the CR170 over the PD170. The better design of the DPF on the CR would outweigh the addictive acceleration of the PD, although I do like my PD170 :giggle:
Personally I would skip the diesel altogether and get another tfsi or tsi. I went from a tfsi to a CR and was very disappointed.
I was thinking keeping in derv land.
It's all down to what somebody want's from a car anyway
