winter tyres
But then I think plastic wheel trims look terrible! :think:
I can't see the wheels from the driver's seat :lol:
Sent from my GT-I9300 using Tapatalk 2
  • Replies 176
  • Views 21k
  • At first sight there is not much difference in the descriptions, but in fact the ExtremeWinterContact is designed primarily for snow and ice, the ContiWinterContact primarily for tarmac. The same is
  • The answer to that is not as simple as it might seem. Insurers can't just impose whatever conditions they want; they must comply with law when they write their contracts. Unfortunately the principal
  • That was true a very long time ago when wheels were located by their nuts or bolts. But all modern wheels are hubcentric: the weight is carried by a flange on the hub that fits closely into the hole a
It's surprising how much of a beating alloy wheels can take. I've bent steel wheels before but not managed to do more than cosmetic damage to alloys. Oilrag, those 205/55R16's are an inch smaller than your 225/50R17's. You'll be driving about 5% slower than you think you are. 205/60R16's are pretty close. Is anyone here running 205/60R16's?
Yes indeed, Goodyear Ultragip 7+. This size offers the advantages of cheaper tyres over 215/60 whilst providing the 'full' side profile to provide additional cushioning effect. Near as makes no difference identical rolling circumference to the originals and they fill out the arches better that the 205/55 tyres too. As far as I'm concerned a win-win situation all round.
As it happens I really didn't want to diminish (IMHO) the look of the car so I purchased some black Borbet alloys to fit them on. Black Borbets on a black car, very Knightrider-ish (only taller!)
Gjay, have you got any photos of that? I want to put 205/60R16's on my (black) scout and keep wondering what dark wheels will do for it.
I just go for uncovered black steel wheels. Totally gangsta.
How about 215/60 R17. Give you more ground clearance, make the speedo under read and more freely available, and possibly cheaper.
If you fit 60/17 tyres you will get very close to part of the front suspension leg. I wonder if the circumference of a tyre grows much with centrifugal force as the clearance looks quite tight.
Unfortunately despite my best intentions last winter I never did get round to taking photos to share on the forum. However I can do better! Head on over to http://configurator.automotivewheels.co.uk/ where you can pick your car and fit just about any wheel and tyre combination you choose and see what it looks like, this was originally part of the Borbet website, I guess they've expanded. I really found it extremely useful when picking my wheels and tyres (from an aesthetic perspective).
Just had a play with that site....................
Why doesn't anyone make a nice "minilite" copy any more? I reckon they would look brilliant. All the ones on there look too "fragile" with thin spokes.
Yes I've been to that wheel configurator, it's very good but still not as good as a photo of a real car. The shadows, reflections and indivual tyre choice can alter things a lot.
Quicky for the experts.......
Will 16" rims from an Audi A6/VW Passat or those from a T4 Caravelle fit Dewi?
I use winter tyres but why do I seem to be the only forum member to stick with my OE size of 225/50 17?
I don't feel I need narrower tyres for driving regularly in fresh snow, just better all round grip in cold/wet conditions and I want to keep the taught handling of my Yeti as it is.
Oilrag - I appreciate you cite 'budgetary constraint' as the reason for going for 16s with whatever size and I appreciate that, say, a 215/60 16 is maybe £40 per tyre less than a 225/50 17 but look at it this way - if you don't get winter tyres you'll be wearing out your OE 225/50 17s so its really just a case of getting a second set of these and swapping them over twice a year. Overall cost in ££££s per 1,000 miles will be the same.
Wheels? Yes; you need these as extra, my recommendation would be the used alloy from ebay route.
I definitely will go for 215/65 R16 (on steels).
Here's one: http://www.drive2.ru...30376152569432/
That would be too great a difference in diameter/circumference to be acceptable in the UK (4.4%). Not to mention the car would most likely handle like a jelly going around bendy bits even accepting an overall reduction in speed in winter.
Those 215/65's look surprisingly right on the Yeti.
How is clearance for tyre chains on the Yeti? Do you need to go to 205's to fit them?
I don't think so.
I own a Mitsubishi L300 on 30x9,50 R15's (original size 235/75R15), not the "sportiest" ride but still ok to drive. Yeti will handle like a Formula 1 even on 215/65's compared to my L300.
Edited by Hirundo
Yes. I ran Goodyear Ultra Grip 8 205/60 R16 96H XL on steels last winter and they were excellent. Someone else here used 205/60 R16s the previous winter and also found them fully satisfactory.
I don't think so.
You might be right although I'd be wary of comparing the handling of two very different vehicles with entirely different suspension set ups and damping. I can only go by my own experience last winter when negotiating a relatively tight left hander with a falling away camber a little too briskly on the 60 profile tyres (winter boots so softer rubber than 'summers') which gave me some cause for concern (Britsh understatement). Personally much as the additional profile might suit the looks of the Yeti (and yes I think 65 profile suits it well), for normal road use I wouldn't consider going higher than 60 profile.
Edited by GJay
//Personally much as the additional profile might suit the looks of the Yeti (and yes I think 65 profile suits it well), for normal road use I wouldn't consider going higher than 60 profile.//
It's not for the looks, but extra cm-s in ground clearance - loads of snow here in Estonia in winter... :whew:
Edited by Hirundo
Sidewall height alone won't cause any handling problems, especially not in the small range you are talking about. It's just a small part of the total setup. The next set of tyres for my 4wd with be 85 profile, sidewall flex on that has never been an issue and I've had it sliding around the tarmac during emergency maneuvers. Traction is an issue, sprung weight transfer a big issue, tyre flex is a minor player. The important part is knowing how your vehicle will react and driving it accordingly.
I didn't say there would be handling 'problems'. I still cannot see going as far as 65 is necessary as any capability increase over 60's would be tiny and the further you move away from oe the more than handling will change.
Just bought a set of Speedline 7J X 16 alloy wheels as fitted to an Audi A6, with the intention of fitting a set of winter tyres, Continental WinterContact TS 830P 215/60 R16 99H XL.
The wheels have a centre bore size of 63.4mm, so I have ordered some conversion spigot rings to reduce the size down to the Yeti 57.1mm wheel stub.
Questions:
Can I use the original Yeti wheel bolts?
Does anyone know if there is a Skoda (or plain) wheel cap that would be suitable? The original Audi ones plug into the centre of the wheel (63.4 mm) and have any outer diameter of about 148 mm, covering the wheel bolts.
I run a set of spitzbergs on mine during winter with Dunlop wintersports.
Keeps the OE look.
