Boost leak on load?
Hi!
I've done a topic like this before but want to try kick it into action again after using my Fab VRS as a bus yesterday!
With only a small load in my car (3 persons) (and sometimes me when I've eaten a large meal lol) there is on occasion a LOT of hiss on boost..actually more whistle than hiss but it is abnormal..Nothing like I ever hear on any other TDi engine'd car and more importantly..not on other VRs'.
Last time I posted I shrugged it off as normal but it clearly is an issue as there is a very slight loss of boost power and its only when the car is on a heavy load and thus under a lot more pressure.
I've had all the boost pipes off and everything appears secure..just wondering really if anyone can advise me..what's next?!
Anyone on here from Ipswich/Suffolk able to give me a hand diagnosing?
I am doing my best to try get a recording but it doesn't happen all the time and so far my recording in the engine bay has come up with a standard boost sound only!!!
  • 4 months later...
Any news on this ?
get your system smoke tested
I'm in Colchester if you want me to have a look, I had a similar problem and have been advised to change the seals in the boost pipe joins. I have them just haven't done it yet.
My wifes A3 130 is the same as the fabia VRS. Upper intercooler pipes either side of the pancake pipe are whats wrong. I have them to do on the A3, top one looks easy, the short lower one looks like a PITA to me, but hey ho.
Hey Sharpyy, Colchester here too... ish
It's fairly easy with the bumper off, it's a Sunday job for when the better weather gets here!
Hey whitep, hope to see you around!
At the moment I am the one with the bonnet up at the side of the road a lot! :-(
Comes with the territory of mods! I have access to a workshop if you need any help :rofl:
Hi,
Just realised people have posted on my post! I've got hold of a compressor and I'm going to do a boost check to hopefully find the leak within the next couple of weeks.
If I don't find anything I'll post again and then maybe I can help other people out with my compressor and test kit..!
  • 3 months later...
Did you find anything?
Ah yes to update! ( couldn't find this post!)
after testing with the bumper off I found it to be the bottom boost pipe.
You can only tell by putting a good 18psi in the system and it's a quiet hiss which gets worse if you jiggle the pipe.
replaced pipe at the hefty sum of 100 quid for six inches of rubber and it's 90 percent gone!
I suspect the last whoosh noise I get is from the coupler on the turbo and this is rare now and only happens if you really thrash the car.
