vrs front disc size
288mm
Standard discs for the vRS are 288 mm diameter, so the second link. You will also need new pads if replacing discs.
Rear discs are easier as they are all the same, (232mm).
Thanks guys. Got the discs. Do I def need new pads. Mine seem to have plenty life left.
Unless you've recently changed the pads, then it is normally best to put new ones on. This ensures both the pad and disc starts off with a flat even surface.
If they're flat and clean and have plenty left, then there's no issue reusing them. Rears might be a bit dodgier as they seem to corrode from the outside edge in, lipping the pad.
