Bolero HU for sale - MkII Octavia
Hello fellow Briskodians!
For sale - in fully working order - Bolero HU from my 12 plate Octavia VRS. Includes manual and the 4 digit code of course.
Reason: Would like to upgrade to Columbus :smirk:
SOLD
Hello do you know if this is a straight swop for a swing radio in a Fabia?
Would this be ok to swap straight across to my somewhat older 2005 Octavia which has a Audience unit fitted?
Octavia Bolero will not fit a Fabia, the radio front is totally the wrong shape.
You will have issues with battery drain unless you also upgrade the CAN gateway in your car at the same time.
Thanks mannyo for helping out here... :-)
What's a CAN gateway then? Expensive or a vcds visit?
Edited by Northlodge
Am I right saying they are around £40?
You might be lucky and find one for that
They are £155 from the dealers for a new one
I can do a new pre-coded one for £75 Delivered
You will also require an antenna adaptor
Yes, I forgot about coding.... thanks Eddie for you input :thumbup:
Would this straight fit into a 58 plate elegance?
I know you loose climate & PDC on screen
Just after something that can alot straight in, no messing about with coding etc
G
I'm pretty sure that it will work but there is an issue with battery drain on older Octavias and as I understand it, new CAN Bus is needed to sort this issue out. :think:
It will work fine in a 58 plate Octy. Straight plug and play. No need to change facia surround either :)
The fakara adapter is required to pick up am/fm radio if you don't listen to am radio you do not need the adapter. Fitted bolero to my 08 plate with nonissues what so ever. Very pleased with it.
Would this fit a 09 plate pre facelift octy vrs - I presume it's just be a plug and play?
Any pictures?
Any pictures?
Yes plug & play on that year Octavia. No need CAN upgrade.
Thanks guys for your interest but the unit is now sold.... :$$$:
