AJ mod - another cheap interior tart up mod
Required...
1 Anti slip Mat From Wilkos, plasticote spray, lacquer, scissors.
Cost...
Approx £5
Time...
1 Hour
Directions...
Cut out sections for the front cubby, handbrake section, cup holder, and rear section.
Spray only "one" side with the plasticote to allow it not to slip then spray with lacquer - this will keep the paint on and make it a little more durable.
Insert and your away!
Does look better in the flesh i must say, if anything it helps the drab interior!
Edited by ajs_vrs
Had these in mine more or less from when I bought it,
had a lump of the non slip matting kicking around so made some
inserts the same. Didn't spray them though. Might make some more
for the new car now you've reminded me.
