Just won a Neuspeed RARB
Well latest purchase is
Octavia mk1 vrs farb and bushings
Octavia mk1 vrs drop links
Dogbone mount (will be installing red powerflex bush)
All for £35! Its bargain month is january :)
  • Replies 202
  • Views 13.2k
  • Okay buttplug, have it your way, but what I was referring to was standard vRS'. In the case of which I fully stand by my original statement. As stock, even brand new, the handling is quite frankly, a
  • You seem to be on some crusade...however I can't even be bothered to read your long winded responses anymore....you are frankly boring now and just arguing the toss for the sake of it... To be honest
  • Aye but on here we know what we're talking aboot so you can be reassured, and read from the background again.
thats good money, but on a vrs with a stock front arb and a 28mm rear arb the car felt unbalanced, the 28mm needs at least a 23mm front imo
25mm farb and 28mm rear arb is not the best combo for a road car !! imo
stick to the 23 and 28mm ;-)
but again its all down to how you drive
yes you are right, 23mm matches the 28mm perfectly...25 is a little too much imo, and 21 is not enough with the 28mm rear.
Ah well
Main thing it was cheap and it sorts out my main problem which is the arb hitting the driveshaft :)
If i feel i want more i will look into it
No need to go balls out from the off
have you got the mount points on the front shocks for the vrs setup Jase???? thought the fr was onto the wishbone
think he is using vrs suspension so with droplinks he can mount to those.
too thick a rear arb will just give you oversteer without beefing up the front to cope, so take it easy, as said in a vrs it felt really unbalanced
Edited by Oet
Fr is onto the wishbone
BUT im using my coilovers from my octavia
Even though its not recommended imo its pretty ace and i have the fixings on the coilover units :)
So the world is my oyster
Aghh its fine using vrs on the tdi, coilies for the vrs are usually same as ones for tdi but have the mount point. either way they will be rated well over 1000kg so itll make no odds
Would a front strut brace beef it up?
Nah. That's bracing the wrong end of the struts, IMO. Need to get the arb right before you even go there.
s3 lower strut brace is a good idea and protects the sump a bit
It will be right
Its a road car
Its got a vrs farb
Neuspeed rarb
And kw v1's
Hardly going to be wrong, no different to an octy vrs driver whacking an arb on! Could be fun i like lift off oversteer anyways :)
And just about every vRS driver that ever fitted a 28mm Neuspeed will tell you it's lethal. Hence why they've all upgraded to R32 arbs.
no a strut brace wont help, all you are doing is promoting oversteer by putting a thicker rear arb on, understeer is far more manageable, the ideal is to increase the vehicles balanced steer basically, so not too much of either or a balance between the two.
with a 21mm front, and a 28mm rear, the car i bought with this setup had a sloppy front end, and too tight a rear end, which felt really unsettled and unbalanced when pushed around corners. Just my opinion having had a number of different setups.
Demonufo sums it up better than me lol
Edited by Oet
Ahhh plonk!
See how it goes!
If i dont reply for a month i am dead and ive reversed into a tree :)
dude, trust us you asked...don't go to the effort of fitting a vrs front arb, change it and get an r32 one, do you want to do the job twice? do it right to start with!!!
I want to keep the pennys in my pocket :)
Just want rid of knocking noise on the front. I may even sell the neuspeed then i have an unknocky car for free and money in my pocket :)
a 25mm bar is better with the 21mm vrs front, a much better match imo
remember your pholosophy on handling mods jase!!!!!! Dibs on the neospeed, ill cover your outlay on it - i can cope with a sloppy front end lol
yours has an even thinner front bar, so would suggest you def need to do your front if you were to fit a 28mm rear
mine has a tt arb
Go! bigger front arb yeah!
Edited by Lofty79
21 or 23mm one?
You might get away with it if you leave neuspeed on its softest setting...
21 or 23mm one?
dont know, it was tight
