Tyre Pressure for 1.4 tsi Vrs
Hi chaps and chapess' probably been done to death, but I hate using the search function for it not to bring up what i want.
Does anyone know what the psi is for the front and rear please?
Thank you
Inside the fuel filler cap
How many in the car?
Good old fashion search function in opening the petrol filler flap and reading the sticker with recommendations..
george
It says 2.5bar however on my old cars ive gone by PSI, even looked on the wall of the tyre and couldnt see it (although it is pitch black outside).
1or 2 at the most in said car.
36psi in the front
35psi in the back
What i've gone by anyways 2.5Bar and 2.4Bar approx
Thank you guys. :)
/Thread closed
I do 2.5 bar all round
I do 2.5 bar but thats a hot temp.
http://www.michelin....ld-weather-tips
Re-set or at least check your TPMS is working, by re-setting after doing your tyre pressures or changing tyres.
george
That TPMS is pants IMO. Ive tried a few tests with it. I dropped about 8 psi out of mine on the last trackday and never bothered resetting them for the journey home. 3 days and about 150 miles later it flashed at me as it had finally registered the drop.
I then changed my rear tyres, all pressures were set at 2.5bar hot again, about 4 days later it goes off again. I went and checked my tyre pressures and lo&behold 2.5Bar(hot) all round, all it had done was take 4 days to recognize my tyres had a lot more tread.
Pants and why people should never trust in it and imagine their tyre pressures are correct.
It might when set warn a driver that a tyre has lost pressure dramatically if they are daft enough not to notice.
Which is what it sometimes just may do.
Mostly useful with 'Run Flat' tyres.
So one finger to press and reset, and cost nothing and does no real harm, i would imagine.
george
right there with vRSy. When changing all four tyres i was a little disappointed that when i pulled away from the fitters the TPMS didn't go mad due to the change. As such i wondered just how good this actually is, especially as the pressures were all other the place as well (can't remember what, but all 4 were different :) when i checked).
it wont know if you have changed tyres! it measures that the rolling speed of each wheel is the same.... so even if your new tyres are different pressures, if they are "the same" it wont notice... what it WILL notice is if one suddenly changes!
It noticed when I had a puncture and changed to my spare - stupid thing! Must check mine today, good reminder this thread ;)
2.5 - 2.5 nitrogen filled..not dropped a bar since inflation coming up 3 months ago now :)
So if all the tyres over time lose the same amount of pressure it won't come up and they are all the same
35psi front
34psi rear
A little bit lower than the filler cap says. If I know I'm going to be carrying a full load though, then I'll beef them up a bit.
yes (although chances of that are astronomical) it uses the ABS sensors, to sense a change in relative speed (compaired to the others) of each tyre... if one is changing there is a puncture... obviously the all change ALL the time as you accelerate/decelerate ect.
I've found it works very well... it picked up a 0.1 BAR pressure change on one of my tyres!
Ah, Yes ,tyre pressures I knew it had been a while since I'd last checked them. Had noticed that the mpg was gently heading south & that the car was a little noisier over speed bumps . . . . Had put it down to these artic temperatures
Usual scenario arises . . . The Air point at the village petrol station has white van man parked in front of it, only to find out he's come to fix it ,again! At least he knew the next village forecourt air was working. :-)
The lowest tyre was 1.8bar,& the highest was only 2.1bar . Oops!
Also added 1 litre oil, 1st time since service 3000 miles ago , that's no thirstier than my 2.0l beetle that the Fabia replaced! :-)
Edited by RazeVRS
So the tyre pressure sensor didn't go off at all? I try to check my pressures every week, but it is nice to have the sensor... if it works!
The only time my tyre sensor went off was when I forgot to re-set it after swapping round the back wheels. But even then it didn't actually go off until about 10 miles down the road.
Nope! Checked tyres at home first, but my cycle tyre compresser was taking an age to put 0.1 bar in .
The TPS did flash and ding after a mile of 50mph driving,to the second garage forecourt . Reset it then topped up all 4 tyres.
On the drive home The TPS did not flash or ding having topped the tyres up though! Thought it would of ,as the tyre circumference would have changed with the added air.
Edited by RazeVRS
I checked mine yesterday, stealer had set them to 30psi front and 28psi rear... stupid stealer. So upped to 36/35... all it did was make more rattles appear (annoying one right in the middle/back of my dash i cant stop agh!) :wall:
Was hoping it would cure the bad pulling i have to the left... but alas, no. looks like tracking/balance check is needed.
My stealer always messed up my tyre pressures, without fail. Had to fork out 20p to correct them every time I got the car back from a service. That's cost me like... 80p in all the time I've had the car!!!
Stupid dealers indeed, hate them! :swear:
  • 4 years later...
Can someone confirm my front tire pressure please?
I have R17, so I did 2.5.
Edited by Chibakun
36psi is the standard recommended pressure for 205/40 R17, which equals 250kPa, so I believe you are spot on! :)
