Vacuum Box
I am currently finding that my vacuum box is buzzing quite a bit, its especially noticeable when i turn the engine off - it'll buzz quite loudly for about 5 seconds. Is this anything to be worried about, will it affect anything? Im not that mechanically minded so I don't really know what it does?!
Cheers,
Marc
do you mean the vacuum box on top of the osf strut?
I'm sure I've read that means it faulty?
Yes, the one over the o/s strut. Im guessing it is faulty but with me not knowing what it does i don't know what the implications are?
Marc
Marc
Yes buzzing/ "mooing" when turning engine off is a common sign of it being faulty.. the vacuum box controls boost pressure so quite important ;).. can cause underboost etc.. they are very expensive new but im sure jason "devontopia" has one for sale..
Does it mean it's faulty if you rev the car and it buzzes
Mine buzzes on tick over and never used too. Im pretty sure it is shot. I have read on here the correct replacement part number is 6Q0 906 625 C. But mine only says 6QO 906 625 on it. If the solenoid is fubar would it negatively affect mpg?.
Think it does, mine is silent so I would say if it's making a noise that's not good
The vacume box is designed to retrieve the air once the power is turne off so in other words once the engine stops and it sounds like its still doing somthing for about 4to6 seconds that's the vac box retrieving all the air so in other words its not faulty and its post to do it.
The buzzing sound it constantly makes is it sucking air in from the filter to send air to which ever channel the ecu tells it too so once again it's post to make a sound.
I wouldn't worry about replacing it till a fault code pops up or u start having vac related problums there an expensive item which don't often play up
You have an ASZ engine then?
that C is the difference between an ASZ and BLT vacuum box. The C is for BLT only mate.
Well my car boost hard then drops of and boost back around but with a deeper exhaust tone anyone now what this is
At what revs does the boost drop off and what revs does it come back
Quite sure it's about 3k the say comes back on at 3500k but it sounds a lot deeper engine noise
I will have a think about this one but I can Not see the vac box being the fault not with it cutting out the boost any way would be good to get it on vagcom to see what it's atually doing
Yes mine is ASZ mate. Just bought a second hand one for £12.50 of flee bay. I will post back once i have it and it's on, see if it makes any difference.
Edited by RAPTURE
Yer you'll have to let us know
I have a video of it dropping off but don't know how upload it on here off me fone
Vtec? :p
New vac box is on, donator car was a 08 Octavia. No difference unfortunately.
Sounds like map sensor, mine did this
Gonna try that next on mine only thing left o.o.
Edited by RAPTURE
Think I paid £17 off eBay for it,was going to get a updated 4 bar one from darkside developments but thought I didn't really need it
U would need to alter the map if u fit a 4bar map sensor.. no real need unless u got a BIG turbo like the GTB ones darkside do.. dont even need 1 with a 150 hybrid..
I didn't realise that, it doesn't say it would need the map altering either?! I did think it was a bit ott so just went for a standard one
4 bar is about 58 psi .... that would be a huuuugggeeeeee turbo on a fabia
