HID Aftermaket kit - Help for definitive how to
Has anybody checked that the bulb failure warning light still comes on for the other bulbs after the coding mods?
Just a thought
Richard
After this coding change, if you unplug the ballasts then it will generate a bulb error on the dash. Proves the CCM is still checking but is now happy with the ballasts instad of throwing a fault.
Has anybody had a set on an MOT light pattern tester to see how the beam pattern scatter looks compare to the Halogen bulbs ?
Beam pattern is the same a halogen, except for a rather nice light spectrum at the cutoff of blue/white B)
  • Replies 302
  • Views 48k
  • Done and installed. 5K is quite bright.   I didn't get any bulb error codes, but I've coded it anyway.   A word of advise for people installing, the brown cable in the original bulb holder is neut
  • Ok, I have 2 different ballasts to test with other than my own. One is an old genuine Hella ballast, and the other looks similar to Vectra1's but different colour. I tried both ballasts and both gi
  • Got mine done today. Another londoncolour kit 4300k. Here is a pic of the balasts inside the headlamp housing on an MY13 FL Octavia Scout. Tight fit but goes in. Bits of velcro to stop it moving too m
When parked after returning from work I face my garage door. I can definitely say they actually give a cleaner pattern than normal bulbs with a very sharply defined cutoff with no halo, colour or blurring (4300K)
Just a thought
Richard
Not sure how relevant this is but my pre FL occasionally throws a N/S dipped bulb warning only if I leave the auto lights on at shutdown. Mostly goes if I drive around for a while with the dipped beam on.
So the bulb warnings still work on the preFL anyway.
Update on an error I made previously. My DRLs DID go off and I was required to change the coding as per Xpower's post. All now working.
Have you actually checked that, as the light source is in a different place now and is a point not linear source.
I ask as the short really high output halogen bulbs can cause issues, so I'm sure these can too.
after a hid fit you need to realighn your beam pattern at a Mot station beam alighner
Xpower, Gizmo, - My HIDS have arrived. Can you let me know when/where you will be in or around B'ham/Coventry and i'll see if we can link up for the coding. Thanks Guys.
Is it obvious which way around the spade connectors should be connected. Red for live, black for neutral or is the headlight loom blue and brown?
Black and brown of which the red live goes to black which surprised me. I connected them the wrong way first.
Coded B19 RAK's HID's, LED number plate bulbs and Oil Temp Display in Maxidot today.
RAK's spec:
  • MY2012 vRS Blackline
  • 4300k London Colour Non-Canbus HID kit
  • ECU 1K0-937-087-AD
Coded successfully by changing the binary in BYTE 14 BIT 4
RAK's spec:
Big thanks to Jonny5ive. Also got my LED numberplate lights and oil temp done.
Thanks to Xpower and Gizmo for offering to help.
I take it this is the way to do it? i have a 2010 VRS, all i need to do tomorow is change my binary code to 10010001?
Thanks guys, well actually i dont want cornering fog lights so it would be 00010001 for me right?
Just took the car down a dark country lane. All I can say is WOW. What a difference!
Works by changing it manually on 2010 vrs , thanks for that guys :)
Got any pics of the hid install mate?
Does the projectors in the blackline give a nice light output without too much scatter?
Really not hard to do. Follow the headlight removal guide in the technical section and google mk 5 golf hid upgrade on YouTube to get an idea of the wiring. Took me about 45 mins start to finish. Hardest thing was trying to organise the coding!
No scatter with the projectors. Nice straight beams.
Consider the rear LEDs too. Do look really cool against the race blue paint.
great thread this. I'm just about to order a set for my 2012 Elegance. Will the long coding fix cover you for fitting an HID High beam too? Or is that not an OEM option?
Not an option as far as I am aware, the option was only ever Bi-xenon on a golf (same) which utilises the same hid projector for dip and main, this is what I've installed on my octy.
Problem is with separate HID in the main, the warm up time really doesn't make them very good :-(
Bi-xenon on the other hand (good set like Hella or Bosch, not Chinese projectors) are truly amazing with no delay.
If you did want to still do HID's in the main beam (say you do a lot of night driving where you don't see anyone for ages) then you will need the ones labeled 'Canbus compatible' which is a lie as the bulbs dont operate on any CAN network but we won't go there - lol :-)
Let us know how you get on!
Here is a pic of mine
Lighting is spot on.
I have them exact ones seem decent just waiting for my canbus error cancellors
You don't need any cancellors. Just code to suit
I know but can't get anyone to code them for me so had to go for the cancellors not a good option but no choice
Whereabouts are you?
Have you looked on the VCDS owners map?
I had wardy do my last scan but he's busy at the moment so will just make do with the cancellors where's this map you say
