Cruise Control
Right then, I
Lloydee,
can't speak for Skoda,but with Audi all we need to do is replace the column stalk and sometimes a small control unit behind the steering wheel and re-code - and it's all ok.
Can't see how it would be different for the Skoda seeing as how a,It's available as an option. b,It uses Audi switch gear and c,the same engine -- so don't see a problem
As for third party companies - AmD do retro cruise.
Maybe Big_K can confirm above... ?
Originally posted by skodaw in this post
Lloydee,
Lloydee,
I can confirm that it is the same as I had mine retro fitted at a Seat garage (Skoda said no) all Inc for
I know I'd get a quick response on this, thanks you lot, Seat here I come
If Bristol isn't to far, Roadworthy Skoda can fit it for you.
Give Chris a bell on 0117 970 1158
They fitted mine and have done about 8 -10 others.
Jon
AMD are well known, and charge about
Roadworthy charge about
Anyone know if a 1.6 can have CC fitted??:confused:
Yes... :)
Rob.
Cheers Rob:D
Was quoted 200 quid (or thereabouts) for it from my dealer/Awesome GTi - that is, my dealer would send it over to Awesome GTi to do the work... :) Was a very reasonable amount, but also equal to the cost of vaccinating 4 cats!
Bit out of the way from Surrey though, but try local dealer, then other VAG brands.
Rob.
Although I do not own a Skoda, I had cruise control fitted to my Seat Leon Cupra by my dealer. I purchase a kit from APR as it was then, which consited of a switch (oe), a wiring loom, and instructions.
My Dealer fitted this in 2 hours, which for there first attempt was good. It required a change of switch, running the loom back to the ecu and switching on.
:cheers:
Which reminds me...looking through Octavia literature at my dealer, it lists CC as an option at
only as a factory order rob....
AMD do retro fit cruise for the Fabia at
Going to place my order in a few days for delivery in a few weeks. Cruise was
Welcome to Briskoda, Andy! :D The usual suspects will be on line soon congratulating you on choice of model and colour, so I will leave that to them.....rolleyes.gif
You know I kind of fancy cruise on my Fabia. I don't know how hard it is to set it's speed (some cruise controls look very complex) for the VAG one, but a few of the rental cars I've been in whilst in the USA and Canada have had it and it is a boon on long straight highways with an low speed limit of 55. The GM version comes in for praise. One touch of the cruise button on the steering wheel and the speed is mantained. It also had + and - buttons to increase/reduce your speed and a button that remembers you last set speed- press it and the car will automatically accelerate back to that speed. Fantastic device. Mind you the car did drink fuel, I remember just after filling it doing 100 miles in a day and seeing the needle noticably down to about a half tank. Not in my Fabia it wouldn't have but then again fuel here isn't
Being party to the usual suspects :rofl:
Welcome Andy to Briskoda,glad to see you have made the right choice........in buying a Skoda,couldn't possibly comment on Model or Colour.
When you've done a few thousand,make sure you follow Denis's lead and make a phone call to Jabba - book the remap,then book an appointment at the doctor's for about a week later to surgically remove the grin :D
When you've done a few thousand, make sure you follow Denis's lead and make a phone call to Jabba...
Exactly how many rumour-mongers are there on Briskoda? Definitely time to visit a solicitor tomorrow!! grumpy.gif
Methinks he doth protest too much!
Chinks appearing!!
Originally posted by fen_l&k in this post
Chinks appearing!!
