Si's mk2 vrs is no more. *SOLD*
Occ drained!............oh my days.
  • Replies 712
  • Views 85k
Neck nomination?
The oil itself is actually fairly clean though which isn't a bad thing
It's the lumpy bits lol..........*barf*
It was full aswell and it's not been piped up properly for long. Better check it more often.
Any tips for fitting the coilovers? Doing mine this weekend alibg with top mounts, inner rack joints and track ends.
Its a fairly straightforward job. Biggest pain seems to be getting the hub carrier off the bottom of the struts on the front. I had to unbolt the passenger driveshaft as I didn't have the correct socket for the hub nut, this was to allow the hub carrier to drop down low enough to come off the strut.
I also took the wipers off to lift the scuttle panel up enough without risking cracking it when taking the 3 bolts out at the top of each side.
That hub nut is a ******!
Make sure you got a m12 or m14 spline bit. I didn't and struggled my ass off. Other than that it's a simple swap ;)
I'm glad mines are getting fitted from my local VAG.
Neck nomination?
Down it! Down it! Down it!
Shouldn't you be outside, sticking rivets to things? ;-)
New pressed plates arrived to tidy it up a bit.
Boredom is setting in so wheel colour choices are being played with :)
hate all them for some reason. green wins i guess :happy:
What about Gloss Black?
Apparently pressed plates are now an advisory on MOT's due to their lack of reflective abilities.
I bought mine with the correct lettering/spacing etc, with the correct standard but the rules have changed.
Just to let you know...
Black is boring, overdone and looks pants so no thanks.
Greens getting to popular now. Saw a new fiesta in metalic brown earlier that looked pretty cool so that may work ;)
Cheers for the heads up on the plates, they are listed as legal so we shall see. I've a nice mot man if not ;)
Ran out of colours on the app now :(
your e36 had green iirc? lol
yea red it is :angel:
It did have green dude and that was the plan for this but every man and his chav corsa have it round here now.
The red does look ok tbh ;)
Bright pink!
yea i didnt quite mean it to come across like tht was just jogging my memory :giggle: :giggle:
yea red looks good man
is this mapped?? if not why are you faffing with wheel colours!! POWER! always comes first :angel:
Bright pink!
Could work :D
Too low to go so may aswell be show ;)
utter *******s!!!! mine scraped when it is was parked and still killed every car it came across :devil:
You need to see it, these pics don't do it justice. It's to low to go quick, a mate followed me the other day and said it looked like it'd been dropped from a height as the cambers mad lol. It'll bounce you off the road ;)
