Octavia II VRS 06 plate blown downpipe flexi
Hi all,
Have reviewed OLD posts on a subject that's been around forever! Here for advice on current options as sure the market and people's experiences have changed.
Flexible part of downpipe has split, I now have a VRS tractor ;-)
I have a Stage one map by Mike @ Motech Northants and no other modifications.
Options from reading up?......
Pipewerx Hi flow cat/downpipe which I BELIEVE fits straight to my current standard rear system £470ish - From what i understand it is still MOT legal, lifetime warranty, not too noisy - current my top choice in my head.................
Correct me if im wrong but from what ive read - low resistance cat/downpipe seems to give a good performance upgrade - with rear system negligible
Repair - quoted £75 at VRS Northampton, also found pipewerx flexi coupler £22 ebay but not researched size or fit method yet (weld/clamp etc)
Considered Magnex etc but above short listed????
Standard part ridiculous price £500-£800 as it contains CAT......and NO performance upgrade....no thanks!
Milltek £1500ish as downpipe only fits their systems NOT standard rear system
While I'm at it, if I do upgrade is air intake noticeable performance wise or just a nicety.....suggestions
Hope you can help before I make a choice and get the bank card out!
I would just get the pipewerx sports cat pipe and fit it onto your oem system it will fit fine.
Thanks Grizzle..... This years 'must have' intake anyone?
You'll get a lot of opinions on intakes. I highly rate Neuspeed's P-Flo.
Mine gained 9 bhp and about 27 ft/lbs of torque on a stage 1 map.
Top end is noticeably better- revs better.
this years must have intake is the Revo intake apparently.
Get a poly lower engine mount insert, it'll stop your engine rocking about and make your flexi last longer.
