Felicia front Wilwood 4 pot conversion
I think i'll order these and make them up to the length required...i hope :D
380489c54a1fd6a1225d322500ae4a59_zpsd543
Edited by ClarkE_123
you don't need swivel fittings, also don't underestimate how difficult it is to make brake hoses, they are a pig to assemble without the proper tools
Rally design will make them up, but i don't want to get the lengths wrong and won't know for certain until i have the calipers mounted and by then i'll need the hoses :P there shouldn't be too much difference in length from the standard hoses though?
For making them up Isn't it just a case of getting the hose cut straight and tidy braiding and getting it in the fitting neatly?
Yes they should be roughly the same length as the oem ones, maybe a smidge longer would be best...
haha you make it sound so easy to assemble them, I promise you they are a royal pain in the hoop to assemble, especially when using braded hose.
For anyone looking to do this.
The mounting holes in the wilwood calipers are slightly undersize, so they need opening up to accept 10mm bolts
It's probably a 3/8" hole then seeing as they are American in origin.
I'd agree with that. Was looking for a technical drawing, but come across a thread about mounting 'em on a kit car forum and i got the drill out :)
