front grille frame
hi anyone know how to remove chrome grille frame from (2010 facelift)
current one damaged. Have purchased new frame and it looks as if it clips on
but not sure
JB
only one screw behind Skoda badge, then a some clips (you probably break some, but you can buy on dealer).
It's the same procedure on Facelift/Non-facelift, although grille differs on external form, fixing clips/holes are the same.
As above mate just 1 screw and just a few clips,easy as peas mate;)
  • 4 weeks later...
When you come to split the chrome frame from the black grill, there are some pointy plastic clips. best way of releasing those I found was a small socket (6mm I think it was) or one of those screwdrivers you can put different bits into and just leave the bit out.
