GTB2260VK with vacuum conversion and flange fully rebuild and balaced for 1.9/2.0TDI
im slightly lost, im saving up to get a turbo from you and oil lines (soon) and want the biggest one with the most power that fits on the stock manifold (to put in blankly).or how much would be it to get another manifold to fit a bigger turbo? whats the best one youd recommend? are these turbos hybrid? sorry if its a topic that's been covered i did have a read through just cant make it out
Thanks sam
GTB2260vk would be the biggest but you would have to specify your power goal and what other mods are you planning to do to choose the right turbo...
the GTB2260vk will come welded directly onto manifold obviously you can go for tubular manifold but it will cost you more than the GTB22 supplied by me...
  • Replies 256
  • Views 79.1k
  • another state of art high spec hybrid turbo arrived today: GTB1756vk with billet compressor wheel designed for 260-270bhp, £750 delivered within the UK. It's not only more efficient but also more
  • Yes mate. 'faboka vrs' is his username. Hidden Power is his company's name. http://www.hidden-power.co.uk/   He's mapped a huge amount of Fabia's on here. Excellent mapper with a lot of attention to
  • Mine will be made by dirty torque developments who have done all the work to my car including a custom fmic
ive got a forge intercooler, ram air intake, full piper decat system and egr delete.looking for as much power as possible realy without injectors but in the future will be getting them i expect. are the gtb turbos the same as darkside devepment ones? and am i right in thinking the gtb isnt a hybrid? and will they fit my piper decat? Thanks Sam
I've never seen a darkside GTB in reality but I guess they aren't very different, and yes GTB is stock 2.7 or 3.0TDI turbo not a hybrid, you have to weld the downpipe flange and see how the downpipe lines up with the turbo it's hard to say for sure without trying most likely some adjustments will be necessary
GTB2260vklr vacuum converted and welded onto 1.9TDI manifold now in stock, comes with oil and water fittings and dp flange as pictured, £850 + delivery + paypal fee for the complete kit
braided oil feed extra £40
oil return extension kit (using the "engine block end" fitting from your existing oil return) £15
delivery within the UK £15
paypal fee 3.9% of the final amount
No stop screw as of yet (will be added in the future) but the turbo is set up and should work fine without it.
Pictures:
Hi mate I'm trying to follow dthrew this thread and can't suss out if you can supply a pd150 hybrid? If so how much? Cheers
please PM me with the details what car and engine code is it for and your power goal and we will figure something out
Thanks sam
You can buy a manifold to fit the gtb2260vk from dirty torque for £750
Bit to much for me mate, probably will in the future tho
Hi, I have a seat leon pd170 and want around 270bhp, how much are you doing the gtb2260vk for and would I need a manifold or does it bolt straight onto the standard manifold?
thanks
paul
GTB2260vk welded directly onto stock BMN manifold will be £700 + £15 delivery + paypal fee
braided oil feed £40
oil return extension kit £15
dp flange £20
You can't bolt GTB2260vk onto stock BMN manifold as it is integrated with turbo housing, it has to be cut and welded onto the manifold or you need custom manifold.
I'm a little lurker here on briskoda as I'm mainly active on SCN, however, I'm just letting you all know about the amazing quality service I've received from XMAN during my DIY Budget GTB1756VK project on my PD130 ASZ Seat Ibiza - http://www.seatcupra.net/forums/showthread.php?t=395773
As Hybrids are just 'too easy' and popular, I decided that 3rd Gen VNT technology with shed loads of boost was the route I was going to take. Being a secret fan of the work done by the lads at Darkside Developments, I wanted a piece of the TDI tuning pie, without spending HUGE amounts of my hard earned cash and softening the blow with gallons of Vaseline.
So after months of research and reading reviews about the quality of turbos that XMAN provides, I decided to bite the bullet and purchased a GTB1756VK with a welded transverse manifold. I also bought the braided oil feed kit and GTB downpipe flange.
The turbo arrived earlier than expected and so the project began. The initial fitting began well however, an adjustable actuator bracket was needed (also supplied by XMAN quickly) to move the actuator away from the driveshaft. I also purchased a oil return line kit which is required to reconnect back to the car.
The stopscrew and actuator adjustment took a few trys to achieve the best spool without massive exhaust manifold pressure (EMP), but nothing testing. http://www.hidden-power.co.uk (Faboka) provided the mapping.
Initial driving results?
Seat thrusting, laugh out loud power which is delivered as a slap in the face! Surprises every boy racer, shrinking their manhood like a hamster in a snowstorm. Unwise passengers claw at the door cards when at full throttle and then are overwhelmed by giggles.
Dyno result?
Best run - 230bhp and 410ft/lbs
Thanks XMAN!
Edited by badger89
thx for your feedback mate ;)
Edited by xman750
Jesus christ.... 410ft/lbs!!!
with stock clutch... it's a miracle LOL
These GTB1756VK's don't seem to mind standard clutches...    Joe's pulled 370ft/lbs and he's still on his standard clutch despite much abuse!!
It's a ticking timebomb! To be fair the standard clutch only has 8000miles on it...
I guess it's because the car isn't very heavy try it on Octavia or VW Passat you will see what happens then...
What boost that Seat running?
Mine is going on the rollers tomorrow, so expecting good things tbh
2 bar
2 bar
Will email once the results are through as I'm hopefully trying low & high boost map setting
7 pages and still not sold? :)   I can't believe not that many are happy to go down this turbo route. :)
LOL I've lost count how many of these I have sold already...
Has any body got any tips and advice on fitting the gtb2260vk as in purchasing mine next week from xman? Bhp,torque and general fitting advice and what's needed, thanks :)
  • 4 weeks later...
Are these turbos still available? How much for a 2260vk to suit a BLT Fabia supplied with a downpipe flange and oil feed pipe and return pipe if I collected it?
yes they are available, please PM me to talk details
