Bearing Dust Caps
Hi all,
I've recently got myself a Felicia Estate so took it to Pendine Sands for a run to check it out, nice little 380 mile round trip to give it a shake down.
Apart from the front brake calliper bolt falling out and loosing front brakes for a bit it was great.
After giving Gerald a look over I noticed the dust cups that fit over the rear wheel bearings are missing and fire out grease over the rear wheel.
Does anyone have one knocking around their tool box? I can't seem to find one online without buying a whole rear bearing assembly.
I'll be at Gaydon Sunday.
Cheers all, Martin
You're best off getting one from a breaking car, simple, cheap and what you need. You may even be able to get one off a vw steelie as they have the same center bore
They are about £1.50 from the skoda dealer... Just bash new ones in there.
It does sound a bit as though your motor has seen some dodgy spanner work. Keep safe now.
Cheers Tom, I didn't think of going direct to a dealer.
And I've given Gerald a good going over Juan, I need to pick up some new exhaust rubbers as the new exhaust that was fitted looks as if they're used the old rubber hangers which are a bit cracked, just waiting to drop the exhaust.
Thanks for the tips guys.
