2wd or 4wd that is the question
Why why why oh why has nobody grasped the point that a Yeti 4x4 is not a god damm 4x4. OK... there is a badge at the back of the car that says its a 4x4 and a stupid gearknob plasticky thing that also sugests its a 4x4.......but its not. Its the same for the Golf 4x4. version....its not permenant. The Golf and Yeti are not 4x4's Fact, end of. Enough with this 4x4 business....its giving my arse a headache.
What is your definition of a 4x4 if its not a vehicle where all 4 wheels are powered?
  • Replies 162
  • Views 24.3k
  • :think:  Please stop the petty bickering, point scoring and infighting.   It's actually really embarrassing to read from the outside, you know when you watch a video on youtube of something like a c
  • Llanigraham
    Llanigraham
    I'm back!!   Some people should do a bit a research before they start trying to define something. The term "4x4" was introduced into common useage during the Second World War by the Allies to defin
  • I was at work earning money to keep Snowy in monster bars and petrol. Sorry, I cant see much of the 'debate' as I have mcamra on ignore. So he can make all the pops he likes about decals and little
99.999999999999999999 % of the time only the front wheels are driving the car. (Ok 5 % to the back wheels). I can tell that just by looking at the condition of my two back wheels which have not hardly used any tread in two years.
Edited by MCAMRA
That's not answering the question, I know how Haldex works.
Because too much power through the front wheels leads to torque steer.
Torque steer is not because of being FWD, but because of uneven torque distribution to the front wheels.  I had a light and relatively powerful FWD car that had been properly engineered with equal-length half-shafts and there was no hint of torque steer.
Back to the original argument around the NEED for 4WD - well there's lots of stuff you don't NEED on a car - power, gadgets, power assistance yada yada but we choose to have them for comfort, convenience, safety, aesthetics or whatever floats our individual boats and meets our personal budgets.
I went for 4WD because I hang around equestrian pursuits and have got at least one 2WD car stuck in a muddy field.  I may also want to pull a horse trailer one day, and 4WD will give a traction advantage on grass etc.  On so-called 'summer tyres' (come on guys, they are not "summer" tyres, they are just not winter-optimised tyres) in last year's snow I easily made it home in conditions that were foxing many cars around me.
Besides, I'm not sure that this assertion that the Haldex IV-equipped Yeti is only 2WD until slip happens is true.  Haldex IV is proactive and can apply rear-ward torque before slip happens.  Plus I am pretty sure that the Haldex chimes in during normal driving too, for example when pulling away.  I also read somewhere that a small level of torque is fed to the rear all the time, but I can't find anything to back this up.
Edited by weasley
Hmmm...  probably true on cars 10 or 20 years old but on a modern variable, electronically controlled 4x4 system, like the Yeti's, you will be hard pushed to EVER tell which wheels are driven.  So the above statement does not hold true.  What is typical "extreme" RWD behaviour?  Oversteer.  I dare you to get a 4x4 Yeti to oversteer and act like a RWD car!  You won't ever be able to.   :giggle:
The key in the above statement was predictability. I don't think that inability to tell which wheels the torque is sent to at each particular instant always adds to safety. Besides, I was able to get my Yeti to oversteer and it was not very difficult to do: ESP doesn't kick in until the steering wheel is turned at a particular angle. So I think the experts are still right ;)
Yes this is true.I have never noticed the front wheels spinning on mine before the rears kicked in. The car just goes without any noise or fuss. Haldex 4 definately takes input from the throttle and will provide full power to all wheels if you put your foot down.
......a car that has 'permanent' 4 wheel drive is a true 4x4. Am I missing the point here ?
.....its not permenant. ..
I've had two Land Rover 110's.  Neither had either a '4x4' badge on the back.  I could decide when to put the drive through to the front wheels by using a manual gearlever.
My Yeti has a Haldex under the spare wheel.  The car's electronics decide when to make the drive available to the rear wheels.
A lot of people would consider the LR a true 4x4, despite the front wheel drive being at the driver's choice.  A lot of people would consider the Yeti+Haldex a true 4x4, despite the rear wheel drive being optional at the electronic system's choice.
Semantics.
They were quite rare, the very early 110's that still had the 4x4 and 4x2 boxes from the series models.
Once the 90 was out all coil sprung Land Rovers were full time 4x4 with just the manual locking centre diff.
So any car that is not locked to a 50/50 power split is not a 4x4 in your book? Almost every single 4 wheel drive vehicle in production has the torque distribution dynamically controlled by a computer just like Haldex powered vehicles.
You must be one of the younger fellas, Boss.  Coil springs?! :rofl:
Any vehicle that gives 'permenant' traction to all 4 wheels can only be described as a true 4x4. The Yeti (forget the 5 %) is not a 4x4. Of course there are exceptions (where you can manually engaged the 4x4 system) however, ....the Yeti (in my book) is not one....as the driver cant overule the computer. Its not permanant.
What's your cutoff o master of nomenclature? 10%? 20%? 49.9%? It is permanent 4 wheel drive as all 4 wheels are permanently driven, just not in a pointless, inefficient manner.
I guess my car doesn't have a throttle either, since the computer just takes the reading of its position and various other sensors and does what it deems appropriate. Just like the Haldex controller.
Taken from this topic :bandit:
Erm, I think you've surely then passed the point of having moved your front pair of tyres to the back to get even wear?!
I have no idea. In order to install the system onto any given car I should imagine you would probably need to apply 'x' amount of permanent traction to the rear wheels just to get the system to collectively work.
5% of permanent traction on the rear wheels on a day to day basis means diddly squat.....and therefore refer you back to my earlier comments.
Its pick on me day. No, the fronts need changing soon and I want to change all four to the same marque....and keep a back tyre as spare on a steel rim.
Just as an aside, I wonder what proportion of 4x4's have been sold with heated windscreens, which I would have thought a key safety feature where the decision to buy a 4x4 is safety-led.
Lots of good points in the above, but the final line is something I find interesting. I always wonder why people don't pick all the extra safety options cars come with, like curtain airbags etc. Surely your safety is worth the £200 or whatever up front?
But at the end of the day, it will all comes down to personal choice and finance.
Good points and as you say - comes down to finance. Or wanting the 140 diesel with a DSG that ONLY comes as a 4x4...
As to the windscreen:  this might help.
Paul52
I very much enjoyed reading your post and totally agree with everything you have said.
I feel though you have missed one vital piece to the jigsaw and that is the psychology and competence of other drivers around you. Not discounting of course that any piece of safety technology an individual chooses to install on their car is limited only to the fashion that those individuals choose to drive their car, but just as importantly you can never really adequately adjust your own driving style to compensate for those on the road who have no due regard or respect for you or their own safety ! I myself will try an install my car with as much 'safety' technology that (as you and the above posters have pointed out) I can afford to protect myself from the supidity, recklessness and selfishness of other drivers....and not forgetting the ever changing weather !
My dad was a 'traffic policeman' in the 1960/70's and taught me one valuable lesson. 'Never be the meat in the sandwich'. Whether that is another car, tree or something else as equally less forgiving.
Could you be a bit more precise please?
recurring !
Presumably he also told you that the most dangerous part of a car is the loose nut behind the steering wheel! :happy: We can only do what we can - drive defensively and keep fingers crossed, although probably not whilst driving.
recurring !
And that too!
Guest
