DSG Oil change
Hi,
Can anyone suggest a good independent gearbox specialist in the Devon area that can do the DGS oil change for me for a little less than what seems to be a standard £180 at VW\Skoda\Audi dealerships?
Needing tax and tyres and a sevice on me new L&K diesel estate, every penny counts!
Steve
£180 ain't bad from a Dealer plus Skoda, if work carried out at a Skoda Dealer,  will guarantee  the work/labour for 2 years.
Very true. It's about £90 for the oil and filter, so an independent won't be a lot cheaper than the Dealer
Do you know how long it takes? I see you can get the oil and filter kit on eBay for £90, surely that and an hour labour plus vat ( or maybe 2) would be considerably cheaper ( cheaper) ?? My local independent garage charges be 30 quid an hour labour.
Edited by vrssteve
I don't know what the book figure is for labour for the DSG oil change. But it's not quite a straight forward gearbox oil change. It has to be refilled through the drain hole with a special VAG rig, then the engine started and diagnostic equipment must be used to monitor the DSG oil temp, which is allowed to get to a certain temperature to ensure the correct level.
It might be 1 1/2 hrs labour at an independent......but I'd want whoever is doing it to have done it before a few times, as it's a little technical.
I got mine for £120 from a Skoda dealer earlier in the year.
£90 + £60 ( 2 hours labour ) = £150 Verses £180 from the Dealer, It's a no brainer
I think I'd like the 2 year guarantee
You won't get that from a Independent Garage, more like 3 months
there's no need for vag-com either.
There is if you want to be absolutely certain that the correct amount of oil is in the transmission.......which on a DSG, you really do.
