1.9TDI BXE reconditioned hybrid turbo based on GT1749VC (PD170)
GT1749vb/vc (PD150 shaft PD170 compressor wheel) hybrid turbo to fit bolt on onto BXE, BKC, BJB (PD105) engines 180-190hp potential,
£400 delivered within the UK 6 months unlimited mileage warranty.
Got one fitted in my Octavia mk2 BXE without any other mods just decat and remap - 175bhp/399Nm well worth the money.
It should also fit BRU, BXJ, BXF, AVQ engines.
Max safe boost pressure 1.65bar
VNT may need some adjusting once the turbo has been fitted so please take some boost logs and make sure it's all good.
As always for mapping I recommend John aka faboka vrs aka Hidden-Power who also wrote nice VNT adjustment guide:
http://www.hidden-power.co.uk/guides/vnt-turbocharger-setup/
Edited by xman750
To assist others, BXE is the PD105 engine or the newer "1.9 TDI"  :)
description updated, BTW I thought that everyone knows that ;)
Edited by xman750
You'd be surprised how many have no idea of their engine code. :P
I've just added some other engines codes which the turbo should also fit
So.... It'd fit a PD105 Roomster then??
Edited by xman750
what's the engine code?
IIRC, and I quote from memory, someone said 'I need 200bhp back in my life' :happy:
Don't know off the top of my head. BXE rings a bell though. I'll check tomorrow.
no can't be I've never seen PD engin code like this
just have a look in your logbook it should be there I guess it will be BLS the turbo would be very similar but the compressor side outlet has a little bit different angle anyway I can get BLS hybrid in within 7-10 days if needed same as for pretty much any 1.9TDI engine
BSW and BLS seem to be the Roomy 105PD codes. AXR for the 101. Well, according to Wiki.
Just out of curiosity, what can you do for a 1.9TDi PD 100 engine code ATD?
the usual £350 + delivery + paypal fee this is my standard price for majority of 1.9TDI hybrids
and what would you recommend I uprated to? A PD 130 hybrid? (remap on the cards, already RR'd at 126 no other mods)
I would go for the PD170 hybrid the price would be the same, even if you won't use its full potential it will be more reliable and you will have room for improvement in future not sure how much power are your injectors good for but as you can see my Octavia PD105 BXE with PD170 hybrid and no additional mods (power related) has now 175bhp and 399Nm after remap honestly I wouldn't hesitate even for a second to choose between PD130 and PD170 hybrid the choice is obvious
cheers, I'll be in touch once I've got some other bits (handling) sorted :)
Would this be a good up grade to my standard one from my fabia vrs.
Its got a good remap on it.
But woundering what the gains are and how relilable these are compared to OEM parts?
what is your engine code exactly? the gain will very much depend on the supporting modes, the engine model etc. the reliability of GTB turbo is much better than the stock one obviously as it was design for 240 bhp cars it has the 3rd generation variable geometry veins, and bearings better spool etc. Just mind that it will require a good custom remap after it's fitted to get the max out of it
I will look tomo for engine code.
Cheers.
I understand about the remap.
But was thinking of things like clutch etc?
depends on how far are you going to go, have you got 5 or 6 speed gearbox there ? I've installed kevlar clutch with pressure plate from VW T5 but I was aiming for 250bhp which is still to be achieved I just need to get good injectors and finally fit GTB
another BXE hybrid is just coming in just PM me if interested
up
another one have just arrived
