New Croatian VRS 236hp 19inches
Bolje da ne racunam hahaha
ali gusti su gusti, nisam to radio da bih ga prodao nego uzivao.
Pa kad me kad sam se vracao iz Cacka gdje sam kupio mjenjac M3me nije mogao stici to je poseban gust.
Ako prodjes kroz Rijeku javi da vidis auto.
Pozzzž
isuse! Koliko si potrosio na auto boze sacuvaj! lol
Looks great by the way. I'll be driving my MK1 from London down to Zadar this summer.
Pozdrav
Paul
  • Replies 1.2k
  • Views 185.6k
  • Tom from sem motorsport decided to make some more  of his big port passenger side (LHD) intakes for me after seen my build thread. At first he rejected me,and after few days me being desperate and con
  • Pay attention to fine precission tools and protein drink
Intersesting read this thread....... Not sure on some of those mods mind, sound a little wacky!
You use 10w/60 oil?
6 speed box should be 02M, not 02J.
As what's been said, you'll be had pushed to achieve the figures you want IMO, even with that setup.... Best of luck anyway!
Steve
Hi Steevie
It is 02J custom made same as Quaife does 6 speed synchro mesh kit. It has new 5th and 6th gear cover, reinforced bearings, "spyder" is also reinforced- guy is Misko from Cacak, Serbia, he is well known among racers, and his gearboxes do not break, and are all in championship cars.
And as I wrote custom made.
http://www.eurospecsport.com/products/transmission/6-speed-transmissions.htm
http://www.quaife.co.uk/shop/products/qke1v
http://www.autotech.com/product/quaife-gear-kits/10-310-210.html?fromcat=jetta-mkiv-vr6-12v
Your 02M is to heavy.
Oil is 10w60 because here is no temp under 10 degree over winter and hot in summer, over 35 degree C, so I see no problem with that, it is metter of climate not engine spec for the oil gradation. Why should I use 0w30 when I drive it hard on track www.grobnik.hr over summer??
You use 10w/60 oil?
Steve
Edited by davojuri
Is your O2J something like the SQS conversion kit ?
I'm guessing by the time its fitted, the weight of the gearbox isn't that much lighter than the O2M
I see SQS do some toys for the O2M too
Exactly but not the dog box but synchromesh kit for daily driven car and weekend track days one.
But basically the same.
So Steevie it can have 6 speed and still be 02J.
Interseting read those links!! :thumbup:
I stand corrected, i've never heard of 6 speed 02J's!
Bloody expensive though! 3k + Euros!
Steve
I paid mine ( look at the pictures) 2500 euro, included in
is montage, Taf X oil, and free of charge change of speed ratios if not satisfied, and most of all housing is powder coated, and all that in Cacak, Serbia,
who ever is interested I can give a contact number, he can deliver it probably with the bus or private driver anywhere in EU.
Worth every penny!!!
emoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gif
Steve
  • 1 year later...
Updates in blue
JBS K03 cast upgrade manifold double ceramic coated from inside and outside
42DraftDesign 3" modular race (decat) ceramic coated downpipe
OE EGT probe from 225hp
Miltek cat back resonated 2.5 inch system
Denso Iridium IK 24 pregapped to 0,024"
Hyperboost adj. DV
Ecotek Emissions Control Valve CB26-P Blue
Piperross Chrome Valve for CB26-P
ECS Tuning Adjustable FPR
034 fuel pressure gauge
034motorsport Vortex breather kit
ECS Silver Lightweight/Under Drive Pulley Set For 1.8T/2.0
Fluidampr Crank Pulley for Late 1.8T Engine
ARP crank bolt
Air intake VDT www.modshack.com
MAF Audi TT 225HP
Air diffusor and 90mm air duct to air box
HKS turbo timer
www.rsrmotorsport.com new custom remap on MAHA LPS 3000
K04-001 turbo,
Siemens Deka 440cc injectors
Large port intake manifold 06A 133 223P
034motorsport Phenolic spacer with transition from large to small port head
New South Performance large on the intake side and small port on the cylinder head side
Forge FMIC- FMSKOFMIC
Forge TIP FMGOLFIND
Forge Silicon Turbo Hose Kit 1.8T 180 FMKT005
Forge DV relocation kit 150/180hp 1.8T
Forge Quickshifter 5spd FMVAG5QS
Mishimoto Radiator Hose Kit MMHOSE-GLF-99BL
Verdict Motorsport Shift Bracket Bushings 42DraftDesign Mk4 & Mk5 Shifter Cable Bushings Fitment Guide
SFS performance custom TIP
LCR (or Lamborghini Galardo) 4bar fuel pump sender unit 8L0919051H (thanks to your site I found perfect match without starvation problems that I had with 044),
Neuspeed 1.8T 180 Degree Thermostat
Neuspeed 180 Degree 3 Pole Fan Switch
Neuspeed Connector Conversion Kit for 3 pole fan switch
Neuspeed Front Anti-Roll Bar 25mm
Neuspeed Rear Anti-Roll Bar 28mm
Neuspeed Lower Strut Brace Billet
APR carbon strut bar
SPEC SV363F Skoda Octavia 1U 97-05 1.8T STAGE 3+ clutch
SPEC SV21S Skoda Octavia 1U 97-05 1.8T STEEL FLYWHEEL
D2racing Track racing coilovers
Ground Control camber caster kit
SPC Performance Camber and Toe Shims 71520 and 71530.
Audi TT Sport Spindle Audi A4 75mm front bearings with two meqssure for inner diameter- can sustain greater axial pressure than OE 74mm ones-required custom work to be done
LSD QUAIFE QDF10R
02J 6 speed custom made powder coated gearbox with Quaife LSD
1. 3.7; 2. 2.2; 3. 1.6; 4. 1.25; 5. 1.04; 6. 0.87; Final Drive 3.64
Audi TT bigger tier rods and tie rod ends (16mm thread)
R32 cast control arms with bigger front bushing (OE upgrade)
Powerflex front and rear control arms bushings
Superpro Front Control Arm Lower - Rear Bush SPF3397K-castor increasing
POWERFLEX BUSH PFF85-505
R32 steering rack
Powerflex bushing all around
Zimmermann Formula 312mm drilled front discs,
Zimmermann Formula 256mm drilled rear discs
EBC yellow stuf front and rear pads-track tested by myself-great ones
BHP (Brake Hose Production) braided brake hoses front and rear
Mintex racing brake fluid,
Castrol EDGE Sport 10W60 engie oil,
Castrol TAF-X transmission oil,
Setrab oil cooler 913 - 13 row
Setrab mounting bracket for oil cooler - P/N 23-9002
Mocal oil cooler mounting bobbins
Mocal oil cooler sandwich plate&+thermostat SP1T
Black Sandwich Plate Adaptor For Oil Temp / Pressure Sensor 3/4 Filter rspec.co.uk
Starlite nomex/kevlar oil lines AN10 blue FSB1000
Ina engineering Baffled Oil Sump:
http://s537.photobucket.com/albums/ff340/davojuri/INA%20Baffled%20Sump/
TWS 8x19 ET35
Falken 225/35/19 F452
Wheelspacers 5x100 6mm 12mm
Painted in red and covered with clear lack rear lights,
Dark grey perforated leather seats and door panel inserts,
Qstarz BT818X 5Hz GPS reciever
Devil eyes headlights:
http://s537.photobuc...ith Ring Bulbs/
Bimarco Futura FIA approved bucket seat full leather
BUCKET SEAT FITTING KIT. RACE, RALLY FIA SEAT. BOLTS
Recaro seat subframe with rails-car specific
RING H7 XENON ULTIMA 120% BRIGHTER HEADLIGHTS BULBS
RING H7 XENON ULTIMA 120% BRIGHTER HEADLIGHTS BULBS RW127.
LED repeaterts smoke Skoda Octavia (1U)
Speedhut Revolution SST RED Shift Light Brand
Custom paint work done:
http://s537.photobuc...tom paint work/
Polished valve cover, boost pipe, catch tank, alternator, intake manifold and TB polished
3M NIMOC High Glossy Carbon black film-door handle, centre console inserts, air vents
Edited by davojuri
Good to see an update on your car :thumbup:
Bimarco Futura
Like those - look very similar to Sparco evo's, but without being quite so loud
Got any pics your leather ones ?
Yes I have
will put photobucket link to it
Some custom paint job
http://s537.photobuc...work/?start=all
two layer of base coat-small metals replaced for large ones (silver) that reflect light much more and 5 layers of Standox 2K laque with added xyralic additive, done by my friend STANDOX instructor
than
-3M Trizact 3000 grinding
-3M green,
- Maguires compound 105,
-3M yellow and than
-3M blue antihologram polishing paste-lasted 10hours a day for a 5 days.
Done by www.poliranjeautomobila-horvatic.com
Edited by davojuri
Looks awesome m8!
Sent from my Galaxy S2 not a Crapple!
Nice :)
Sory my mistake
breast reduction
will delete right now
ooohh beast. Subscribed to this 1. Welcome to the forum :)
Green rules :-)
:thumbup:
Not fitting yourself ?
I bought it because of its height and holes for seatbelt are high enough not to cut through my shoulders because I am 194cm and 100kg of muscle mass.
That's why I didn't go for the Recaro SPG XL-holes are lover in position and backrest isn't that high.
But it seems to me little to narrow at hips region.
Compared to my friends OMP BIG (now called WRC XL) to small.
OMP is like tailored for me so I am selling this one that is completely new, never mounted to get that OMP.
Edited by davojuri
Gates T306RB racing timing belt blue
Edited by davojuri
AGN smooth valve cover-polished
Edited by davojuri
Updates in blue
Hyperboost adj. DV
Gates racing timing belt blue T306RB
ARP crank bolt
MAF Audi TT 225HP
HKS turbo timer
K04-001 turbo,
Forge TIP FMGOLFIND
LSD QUAIFE QDF10R
Powerflex front control arms bushings
R32 steering rack
Setrab 90 and 45 degree and straight one swivel hose 10AN fittings
Mocal oil cooler sandwich plate+thermostat SP1T-POLISHED
http://s537.photobuc...A Baffled Sump/
TWS 8x19 ET35
Polished INA baffled sump, valve cover, boost pipe, catch tank, alternator, intake manifold and TB polished
Global HPC green 20 window film
NEW Throttle DV hose blue
with ALU straight 63mm joiner
with 76 to 63 straight adapter for
S4 70mm Throttle body
INA TB adapter plate 70m through
Intake manifold port matched to 70mm
Edited by davojuri
