Daniel's Seat Ibiza Sport PD130
Hey Dan... what did you use to clean up the EGR and inlet? I suspect mine will look just as bad. Did you not consider an EGR delete kit? I'm wondering if its worth it for around £50...
Hello Dan!
I used a few things mate, tried petrol, paint thinners, some random drain cleaner but none came even close to caustic soda. I got a bottle from Boots for £3 (although had some lying around the house as it's great for removing annodising from bike parts!) and it took minutes to dissolve all the carbon deposits.
If you do get some though please be careful using it! It is incredibly volatile and burns skin in milliseconds. Also the fumes are disgusting.
I did consider an EGR delete but thought i'd take the hands on approach first. Got an EGR delete on the way anyway just to remove the restrictions in the egr itself. Hope that helps mate
  • Replies 165
  • Views 38.9k
  • Spent this afternoon on and off reading this thread. Has to be one of the best build threads going on Brisky. Totally inspired me to get stuck into my car and get my hands dirty for once. Looking f
  • Did he get back to you? and how much did he quote you?   I will warn you though, don't go there without a dog / girlfriend / mate / banana suit to entertain yourself with. The town is so small, I fo
  • How are your boost pipes holding up? I got fed up with mine popping off, and was loathed to pay the extortionate prices for replacements, so I fixed them properly They're still holding up fine,
Hey!
Quite a few updates from the past few days. I've fitted a powerflex dogbone mount bush, EGr delete kit and finally plumbed in my boost gauge!
I fitted the EGR delete pipe first. I did block my EGR vac pipe off originally however the restriction within the egr is still there, mines also leaking like mad everywhere so probably losing me boost there! Also gets rid of another horrible VAG boost connector clip and replaced with a jubilee clip :)
Here they are!
My original EGR in the top left
This is the EGR delete compared to the normal EGR pipe. The thing sticking out is the nipple for the boost gauge!
EGR valve
Then removed the EGR pipe to the EGR and blanked it off with the plate provided in the kit.
And after!
I didn't have anything to simply block the nipple off and didn't have enough time / supplies to fit the boost gauge yesterday as I needed some more piping. IMPROVISSSSEEE! haha Worked a treat
I then set out to fit the dogbone mount bush. So easy to remove. 4 bolts and it was off. Absolutely no need to support the engine whilst doing this
The old one has so many gaps in it no wonder the engine rocks so much when putting your foot down.
Little bit of wiggling and it was out. Removed the rest with a screwdriver and hammer
I didn't realise it would be so hard to press the new one in so I had to use some common sense / reach into my inner pikey and thought of doing this. It actually worked hahaha, pressed it in with the jack and using the weight of the car.
I used a small vice to finish it and pop it in properly.
Will give my comments on it at the end :)
I then went and bought some more boost gauge piping, I used this stuff from pets at home. It's meant for fish tanks but fits absolutely perfect!
Started wiring it through the bulkhead. Also reallllly not sure what this black pipe is for? It did lead to teh engine bay but wasn't connected to anything and it had a little nipple connector on the end. The end is on the right of this pic?
Fed underneath the heater controls
Also due to the T fitting I have I had to make something to block the other connector, I don't have a straight through connector with the antibuzz fitting inside only this T piece so i'm doing this, for now maybe until I find a proper connector but it works a treat.
I then started to wire in the boost gauge so it comes on with the sidelights and the headlights, out with my best mate. The multimeter! Was just a case of prodding a few wires to find the one that showed just under 12 volts when turning the light switch.
Found it!
Then started testing it with the bulb that goes to the back of the boost gauge
Off....
On...
All done :D this is with the lights off
And the lights on :) Ive ordered an LED bulb instead of the filament style as its very yellowy and ruins the look of it imo
Anyway, little bit of feedback from installing everything:
The car now absolutely flies, i'm not sure which made the biggest difference but the car just feels so much more planted when hitting the loud pedal. The engine doesn't rock back and forth and changing gear is just seamless now with barely any hesitation. It just pulls and pulls and pulls. So much fun and I can't wait to jump in the car now.
It does have a slight vibration on idle and when setting off but it's not an obtrusive rattle at all, it's more of a meaningful rattle like the car means business if that even makes sense? Just feels right.
It picks up so much better now and tapping the throttle is instant power now whereas before it used to hesitate ever so slightly. Would recommend the bush to anyone, for £30 I'm going to say it's the best price:difference mod i've done this car so far.
What a brilliant thread so far! Well done mate!
Sent from my Nexus 5 using Tapatalk
Great reading ! Keep it coming!
Hello.
Today I finally started to fit my cruise control stalks and wire in the loom. It was so frustrating as the wiring is hidden away and the plugs are the same. You relaly have to fiddle around getting the plugs out.
Started to remove the the side panel to gain access to the control module.
I then removed the light switch panel, the wires dangling are for the lights.
First blooooooood!
This is what it looks like as standard, I then have to drop the box with the red wires going to it along with the relay box behind it to gain access to the plug where you have to fit the wiring loom into.
Control module dropped
Relays dropped!
This box of plugs is what I thought I had to connect the wire to but boy was I wrong haha, turned out its way to the left away from easy arms reach.
Finally got the correct white plug out, required sliding a metal bar to the left to release it from its holder.
I then slotted the wire in the plug, initially releasing the purple pin holder to allow to fit the new pin in.
Bye bye wire!!, plug back in its holder and the wire loose.
I shoved my camera right in to show the white plug where the new wire goes into, as you can see it's pretty far back!
Started to remove the steering wheel too!
Bought the correct tool too, my first "proper" tool i've bought as usually we've got it in the box. Mandatory cup of coffee in the background too haha
I then started to remove the cowling to gain access to the stalks to swap them over and wire in more of the loom to the connector at the back of the stalks.
Before and after, Spot the difference!
This is the connector, notice how there are plug gaps at the top then look at the next pic to see where the new ones go!
Started to put it all back together
I then had to wire in a final wire to the fusebox, I went to one that comes on with ignition as I don't want power constantly being fed to the loom.
Few more pics of me doing this!
Then finally I had to activate it on VCDS, thanks to my Dad's trusty million year old laptop haha. The battery lasts 10 mins after a full charge so I had to be quick lol
Started putting it all back together!
I also caved in and bought a black boost gauge, the silver one didn't go too well and this looks much better imo!
Yay all in, works an absolute treat, I genuinely can't believe it worked first time as I thought I would mess up the wiring somewhere. So so happy :D Sunday's drive to newcastle is going to be so chilled now
great write up    where do you find the time:-)        p.s I don't think the door buttons are supposed to "work"  just indicators     what's next?
Cheers man :)
Haha well i'm in 3rd year at Uni now so get a few days off Uni as it's more independent learning but luckily I nailed loads of my dissertation in the first few weeks so i've got a bit of time on my hands!
I'm not sure what you're referring to about the door buttons though? Please explain!
Next "big" update will be the fitting of the turbo and the remap which will be after Christmas although maybe some stuff inbetween as my girlfriend has just asked me if I want to work for Everest this christmas = money which is ideal! Worked as a canvasser all summer which was fun (ish)
I think the door buttons were only ever a locked /unlocked indicator    first mistake I made was to pull one off   that was on a brand new car  so shouldn't have been a fault   cheers Nic
Yep they are, they don't do anything, I get you now. But the passenger side comes down and pops back up again. Still haven't fixed that actually haha
Just a small update
I gave it a semi detail (clayed with bilt hamber auto clay, washed with citrus wash and gloss, one coat of srp and one coat of Colli #915)
And removed the drivers seat to properly clean behind the gaps as they were really bad. Didn't do the passenger as the bolts were a nightmare to remove without the proper m10 spline tool so got one in the post to fully complete the job!
First with the wash / detail afters!
Also I found my bottle of G1! I then stupidly dropped the bottle with the lid off whilst being distracted by being on the phone. The smallest bottle in the world and I dropped it alllllllll !! £12 wasted haha
Last one is my fav shot!
Then on to the removal of the seats :) Look at the dirt inbetween the seat and the door trim bit
Then I found this little thing, I was like eh is this a switch for something?!
Wala!! So happy as I need a bigger memory stick haha. Car is paying for itself :D
This was under the seats!
All done :)
Clean
Drivers side done
Random pic of the cabin
I think if/when you come to sell this car mate someone will snap your hand off if they read this thread and see the amount of time and effort you've spent on the car. Really does look like you got yourself a cracking motor there now!
Car is looking so good mate! You've done a few of my plans too. Where did you get your boost gauge if you don't mind me asking.
Thank you so much for that mate!! :)
I'd love to sort out all the dints but it would cost me so much, might do it myself but I know how hard it is to get filler perfect etc
Hey dude I got it from eBay
http://www.ebay.co.uk/itm/221317641427?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Cheers dude. Just had a look, some quite nice ones on there.
How would you recommend I block off the boost nipple on the EGR until I get a boost gauge?
Thanks for the help.
I used a combo of connectors from a fish tank with some clear piping so that it bends back on itself, something like this! It's a bit of a bodge job but worked :)
I was told that bending over a bit of silicone piping like the fish tank stuff and cable tying it tight would also work but I luckily had these spares lying around the house (not sure why as we don't own any fish haha)
Ignore the Y piece coming from the boost pipe, was just showing you the arrangement with the blue plastic connectors. Might give you some ideas but no doubt there will be an easier way haha
Cheers Dan. That's a cool idea. It would only be temporary until I bought and fitted a boost gauge.
Am loving the mpg hunting by the way, same as what I'm doing! Hoping the planned elephant mod and EGR delete will give me a bit of an increase.
How have I missed this thread?!
Top work mate, seriously. Love a well written build thread.
Would love to know if the airtec FMIC would fit a Fabia, in terms of trimming the bumper and foglights etc.
Will be keeping an eye on this.
P.s any plans to change the yellow dial surrounds?
You just need to find yourself a good paint less dent repair person who will do you a rate for the whole car regardless of the quantity of dents. I had about seven or eight dents of various sizes done this way.
Cheers bowen!! :)
About the dials, I'm not too sure tbh mate I quite like them yellow now, it's a bit different :)
Nothing too exciting really. Made an attempt at cleaning the engine bay, didn't have much stuff to use just standard all purpose cleaner but couldn't really do with some degreaser. Will dress the plastics another day, just wanted to clear the first bit of dirt.
Befores
After
And had my car tracked in Huddersfield with their Hunter aligning kit. £50 which was pretty good but you can't adjust the camber or castor on my car so just the toe was altered.
Dan how 'different' does the car feel after the geometry set up? I am researching for a forthcoming project car which will almost certainly be an Ibiza sport pd130.
ATB Dave
Love this thread Dann :thumbup: some great little touches, plus I think you've convinced me to change my engine mount as it looks pretty straight forward :) although now not going to touch the cruise, think I'll leave that to Tech1e :D
ATB Dave
Hey man, I did comment in your thread but I think you might have missed it as I posted at the exact same time as someone else.
Well as the camber and caster can't be adjusted on this model all they could change was the toe, consequently thrown out when I put a new track rod end on. But after the alignment it felt brilliant, used to pull to one side when braking hard and I didn't feel too confident on where I would end up but now it's much better.
I do feel like it's lacking something though, wish I had uprated my wishbone bushes to solid cupra ones now. Or fit lowering springs and shocks.
Thanks a lot Jars! Yeah changing the mounts is fun as it's so easy, 4 x 16mm nuts and it's off. Just ensure you've got lots of grease when putting it back together so it all slides in perfectly is all I can advise really :)
I think this is a great direction to go in, some good springs and shocks and maybe some superpro polybushes or the cupra ones.  All money really well spent to get the most out of the car, for me far better than adding power, or at least the better place to start.
Only downer is after each you will need to take her back to Allcar to get the alignment done again.
Might not be for a while now as i've just bought springs, a shock and those oem bushes haha. I knew this would happen :(
