What headlight bulbs to buy?
I have a fabia vrs mk1, was just wondering what headlight bulbs i should buy, wanting xenon bulbs but not really sure which ones to buy or which ones fit :D
Would be good if someone could help meeee :3
Osram Nightbreaker Plus would get my vote
What would they be though "H7 or H4"?
+1   or Philips but they are usually more expensive
My Haynes says- fog =H3, Main =H3, dip= H7,for Halogen. On Xenon ,it says H7 halogen on main and D2S (80-117volt) on dip, suggesting morec kit is needed . I've found sticking in dearer lamps means less life. I've always found Furby lights excellent ,with no need to upgrade . I now buy cheap lamps and they last longer with the same light output.
I bought a set of H1/H7 Supreme White Xenon Power bulbs thinking they were going to be as good as Cobalt II bulbs I had before...
Worse than OEM fitment Osrams, steer clear!
Found an outlet that does the Cobalt IIs for £8 a pair with free postage, now where's my plastic.
I had nightbreaker plus but they both died within a year so I've opted for the more expensive philips Xtreme now.
interestingly Philips were a dealer fit upgrade  option in Holland 10 years ago and while not doing a lot of night driving are still in there--touch wood
I have a fabia vrs mk1, was just wondering what headlight bulbs i should buy, wanting xenon bulbs but not really sure which ones to buy or which ones fit :D Would be good if someone could help meeee :3
As always, I reccomend OSRAM tool for detailed specs on your car...
http://am_application.osram.info/publish/index_en.html
BTW if Halogen are H7 lamps, I suggest OSRAM Nightbreakers (for white) or Cool Blue Intense (for bluish)
If you have Xenon then you have OSRAM XENARC series (lamps are D2S, 85V 35W P32d-2
