Dip it, dip it real good!..................(a DIY wheel refurb thread)
just to check sparkly, can you simply peel this pain away if you fancy a change?
Allegedly
  • Replies 149
  • Views 15.8k
  • Beats me, I have tried on many occasions to enlighten her as to the difficulties in finding the correct canbus error free LED 42mm festoon in order to have a better lit rear number plate but she fails
  • Aaaaaaand we're done Pretty happy I replicated the original wheel, which still requires more peeling, sigh. The wheels looked really distinct until the pearl coat, it is insane the change one coat
  • I think this is finally the thread that will convert my wife to accepting that Briskoda is not in fact the nickname of my mistress - especially as my default Christmas present to "her" is a new set of
To mask the edge of the wheels such on Gigaros around the machined edge, you can use Coach lining/pin striping Tape to mask,
or just get the correct thin masking tape.
george
Am I right in thinking though that relative to say masking off the tyres this would need to be meticulous in order to get a good outline.
I'm also unsure how the dip would react when you pull the tape, no basis for it, but I might worry that it would tear.
Where simply implies 3 hours of swearing and ending up with everything covered in little bits of the paint stuff.
195/50 R 16 could actually sit a wee ticky taller than the 205/40 R 17's. mine did. which was a good thing for winter, snow etc IMO
http://www.kouki.co.uk/utilities/visual-tyre-size-calculator
I just thought by the picture they looked a bit smaller,  please no tape measures, just sat side by side will do.
george
Edit,  you would practice with the tape on the edge you are masking, no idea with Plasti Dip or similar.
Depends on thickness you are using of coating and removing masking soon after finishing, not leaving it on till later..
I mask , then spray, remove masking and lacquer, the edge.
With paint it is rather different.
PS, and there are many widths of Masking tapes, Art shops are a good place sometimes rather than Motor Factors.
what you used then faster masking with wide tape, sometimes when not using paper or plastic.
Allegedly :rofl:
Personally believe would be ok from a well prepped wheel face, if enough coats, deviate from that and........well the above :)
Allegedly :rofl:
Allegedly :rofl:
I just get the feeling the bits would cling to anything it came into contact with, including you, the floor, walls etc.
george
Depends on thickness you are using.
George, I know you know your onions on spraying, as you've mentioned in previous conversation the dip sprays pretty thick and I think this would hamper detail work compared to paint.
The above was my thinking on the winter profile I picked 50% of 195 is a shade more than 45% of 205. Will try to get a side by side shot, I think the Vred's might stand quite tall, I also need to double check my tyre pressures.
This is fortunately false, totally.
I had my test wheel in the front room on a mat peeling off the sidewall overspray, the peeled bits large or small are pretty inert, like how shrink wrap works is a good explanation. Dry, no tack and can be picked up with a DustBuster.
195 does not mean automatically less tread on the ground,  195 205 215 etc is the tyre width,
not always the same as tread width.
i have some All terrain & road 195's that are wider than All Terrain 205's I have 215's that have less tread on the road than both of those.
do you actually collect tyres geaorge ?! ;)
Rubber fetish!
I do collect tyres, always 2 spares for each set, & a tyre type for every job.
A shed full of tyres and rims as well. Mostly they are on cars though.
Waste not want not.
I think this is finally the thread that will convert my wife to accepting that Briskoda is not in fact the nickname of my mistress - especially as my default Christmas present to "her" is a new set of wheels and tyres! (Sehr romantisch!)
I've only had this car just about 6 weeks and have now bought my second set of wheels and tyres in addition to the original ones. I ought to compare sheds with George! (Wouldn't be surprised if we've got the only TT running on all-terrains!) Latest are some smaller 16" ProRace 1.2 for winter use. They're 7" and ET38, so should look OK on the Fabia but the 205/45s won't provide much protection from kerbing. Have to be careful won't "she"! Maybe even go for some 205/50s next time if they'll fit in the spare wheel well. Wheels were a steal at £80 each even if they're silver, but I might have a go at dipping on the strength of this thread...
George - I'm slightly disturbed by your baby sitting episode, and just wonder if the child is now glue sniffing in some scheme! I might suggest to Angelina that she can dip her next baby if she's not happy...
They could be glue sniffing, but i think probably more likely it is white powder, they are a Politician now.
That's some fairly posh alloys to have as your winters.  Treat them well, a lad at work has just mullered one of his lightweight OZ alloys on a pot hole and the thing has been warped quite badly making me think these lightweight wheels aren't as tough as their porkier OEM cousins.
Reminds me of some on else, or is it wheels you collect, or both
  • 4 weeks later...
Hows the dip holding up Sparkles?
I think i'll probably do my Leon wheels in matte white when i next need new tyres
I'm not 100% sure if it is down to driver error and I have nicked the wheels Mr Pasty.
But I have two small marks on the outer rim of two wheels, I am suspecting it is probably my fault being over confident with my new tyre wall depth.  Only see the nicks if you get your nose right up to the wheel and it's also possible it has happened on a point where I have sprayed a tad thin.
Otherwise holding up just fine.
Just spray over the marks again. Plasti Dip will bond old and new paint as the fresh paint will solve the old.
Yup that's correct, new layers melt and fuse the old, I am not sure how this would affect the overall finish.
As it stands it's barely noticeable so unless it deteriorates then I will leave it.
excellent news
time to decide what tyres to buy :thumbup:
Don't scrimp, go for something quality, Ling Long or maybe Sunny :)
Ling Long; Sunny; Wanli - all fking ditchfinders !!!!
Sunny - worst pieces of "rubber" i've ever had the misfortune of having fitted.  Wheelspin at 75mph in 4th (on an Autobahn, before anyone pipes up) is NOT a pleasant experience.  Only reason I've not put them on the back is I prefer to see where I'm going..
The smiley face was ironic chaps :)
