LED 'puddle' lights
bought some white led strips off ebay for a couple of quid after deciding to tap into to red lights in the door card to make 'puddle' lights.
parked in a multistorey to test them this morning after fitting.
DSC 0285
  • Replies 134
  • Views 13.8k
  • Update today folks......   I had opportunity to mess with the door panels after the rear passenger door was playing up, due to door wiring loom having a break in it somewhere(same issue are drivers
  • Well here you go guys   Rear door's done and working great           New thread for rears in techi section.   http://www.briskoda.net/forums/topic/296851-how-to-install-rear-door-pu
  • Well done to OP on this....great mod   I knocked up a quick install guide and added it to techi section for folks wanting to have a go.   found here :   http://www.briskoda.net/forums/topic/2960
Thats a pretty good idea is that.. might have to steal it for my furby :)
Looks really good. Can you put up a pic of where you have mounted them to please ?
they are mounted on the bottom of the door pockets on the little lip they are held on with double sided tape so il have to see how long they stick or i might use a bit of silicone to hold them on. they cost about £4 on fleabay for the pair.
DSC 0291
DSC 0286
Nice!
Thats cool. Been toying with the idea but never got round to doing it. Thank you for the kick up the bottom :)
took about 5 min to wire up each side, drilled tiny (3mm) hole in bottom of door card to feed wires through then tapped into the existing light wiring.
Very nicely done!
Could I be lazy enough to ask you for a link to the ones you bought? Really really like this idea and fancy shamelessly copying you, ta :)
Here mine on the fab...took all of 10 mins to fit.
Steveday. The item number on fleabay is 281031039002
Certainly effective these dark wintry evenings/nights..
Smart mod. Like it!
V nice!!
Top man, thank you very much!
They look smart actually, I may try something myself
Liking this mod. And great value. Nice one guys.
Sent from my Samsung S3
I was going to do this a while back, with special ones that project a Punisher skull on the floor.
How did you actually go about doing this? Just pull the door card out a little to access the wiring... or was any drilling, etc involved?
Stops u standing in dog **** at night:)
Stops u standing in dog **** at night when u get out your car:)
I just popped out the red light thats already there to access wiring then drilled a 3mm hole under door card so u cant see it and thread the wires through.
I think being sent 2x2m strips of leds might be too long to fit doors. Stupid seller
If its the same strips we used at work then they can be cut down :) used to fit red versions of them on the doors of ambulances facing back.
I thought about getting these and removing the Skoda filter..
http://bit.ly/1bOSfkm
