Enabling cornering fogs with VCDS - updated for vRS
No probs, I'll pm you Friday morning. I sense an unofficial O3 owners meet in East Lancs coming up ...........
Sent from my phone so please excuse brevity and spelling
  • Replies 191
  • Views 49.2k
  • Just checked, they do both come on when I put it in reverse which is not a bad idea especially when you are reversing out of a tight spot and the front swings at a large angle!
  • I  now have 2 rear fog lights - an absolute doddle!   I'm posting the adaptations in a minute.   Why Skoda dealers can't get their head round this is beyond me ............   http://www.briskoda
  • Nice work lads. Shame the same can't be said for Skoda UK   So as originally thought, instead of simply activating the cornering fogs during manufacture, Skoda UK have instead decided to issue a rev
Great, looking forward to it.
How about changing the speed that lane assist activates?
Can have a look, but haven't seen that documented anywhere yet
Ok, cheers.
I am very tempted, is this an open invite : ) Will be a bit of a trek from Derbyshire though!
I'm just by Jct 25 of the M1 and I have VCDS if that is any help.
How could I refuse! Thanks...shall I PM you to arrange for a time?
Yes, drop me a pm and we can sort things out.
Result. It works (once you remember to turn the headlights on...)
Many thanks for sparing the time to set it up!! Really chuffed the cornering fogs work...and as an added bonus, the needle sweep is really cool! Thanks again.
Do they both come on when you select reverse?
Didn't notice when ssfan left to be honest.
If they don't then it may require an additional adaption, as you had to do the left and right hand sides separately as per the link in the first post.  Unfortunately everything is in German and there must be over 100 possible adaptions listed in the controller, so unless we have someone proficient auf Deutsch it could be a little tricky.
No label file was available for the long coding in the controller so no chance of doing/checking it that way.  I will send a copy of the autoscan results to Ross Tech and see if they can work their magic.
I also noticed that when you do an autoscan or access the infotainment controller the radio can't be turned off.
Edited by ssfan
Just checked, they do come on when I put it in reverse which is not a bad idea especially when you are reversing out of a tight spot and the front swings at a large angle!
That makes life simpler.
That's great to hear the full corner fog can be enabled :)
When mine eventually turns up I'd be grateful if someone with the VCDS could enable this system.
TP
Could either Trundlenut or ssfan post up what needs to be done in VCDS to enable the cornering fogs please?
I'd be willing to pass a crate of beer to someone who could give mine a once over and enable cornering lighting..
Just follow the link in the first post - using google translate of course.  The only issue was the list of adaptions in VCDS is very long and all in german, so you need to scroll about three quarters of the way down the list to find the two relevant entries - make sure they are exactly right:
The adaptions are done in the central electrics controller (09).
Select:
(5) Leuchte12NL LB45-Lichtfunktion B12
then:
(5) Leuchte13NL RB5-Lichtfunktion B13
and change them respectively to:
Abbiegelicht links anpassen
Abbiegelicht rechts anpassen
You need to use the access code of 31347 before going into adaptions or the adaptions won't take.
You also need to turn off the ignition, remove the keys and start the car for the adaptions to take effect.
Whereabouts in Staffs are you?  I work in Burton on Trent if that's any use, but I'm off now until the 2nd.
Where abouts do you live?  PM me if need be,
I am afraid I my total input in the whole process was to unplug the lead after it was all done! Trundlenut did his magic on his laptop and then it all worked .... well, once I turned the headlights on LOL
Excellent. I'll be after a hand with this once mine arrives. I'd miss cornering fogs having liked them for five years now.
Neily03 now has cornering fogs on his vRS.
As well as
Rear Teardrop wipe
Passenger wing mirror dip on reverse
Rain Closing
Automatic boot closing from interior button and remote fob
Then the battery died on my laptop ..........
AndyVee, what do you mean by rear teardrop wipe?
