Removing Fuel
Hi All
My wife has a 59 plate Fabia petrol estate. She will be p/xing tomorrow towards a new car but has 3/4 of a tank of fuel. I have a few fuel cans and wanted to get some out rather than swap it in with all that fuel.
I have put a tube down the filler but I can't seem to get anywhere and when I remove the pipe it's still dry.
Any advise how I can get the fuel out easily
Glenn
most modern cars these days have anti siphon measures built into fuel systems. you probably have to drain it via the fuel filter pipe downstream of the main tank.
Don't bother.
Just ask for a tank of fuel with the new car.
Modern cars have filler necks that are designed to be anti syphon so its a pain to get fuel out, maybe you will have to investigate under the rear seats to find the fuel pump and see if access to to remove the fuel can be had there?
I have seen a desperate person drill a hole in the bottom of a tank on an A4 to get the petrol out so he could put its preferred diesel back in, my advice then was to pick a drill size to suit a tyre valve (we had one in the toolbox) and plugged the hole with that. Oh if you do go this way I would also recommend a plastic bag over the drill to make sure the fuel doesn't ignite on the electrical sparks inside as the fuel floods out all over it!!!
Don't bother.
Go with this!!!!
Speaking as an ex tech, you wouldn't in any way be serious about that advice would you? Just to make sure you know, its illegal to tamper with the fuel system of any vehicle in that way and then use it on the road. That's to say nothing of the danger doing the job and the obvious problems that will follow. A tyre valve won't last either as the solvent action of the petrol will dissolve the rubber off the tyre valve. And it will leak from the off!
Edited by Estate Man
We've had some success with disconnecting the fuel return pipe and running the engine with the fuel return rerouted to a container rather than the tank.  Obviously you'll need to take sensible precautions with a running engine and exposed fuel.
Just let the car go with the fuel ! Just let salesman know and they may fill your new one up ?
Would've been easier to not have put as much fuel in if you knew it was being part ex'd.
The salesman's not going to put a full tank in the new one just because the trade in has a 3/4 full tank!
I wouldnt bother as its not worth the hassle .
Talk about being tight.
Seriously, it'll be £50 at the most, would you have turned down the offer if the new car was £50 more? I don't think so. So let it go, it's not the end of the world, and you won't lose anything by asking for something in return, fuel, spare oil, car mats, anything.
Don't bother. Learn from your minor error next time round!
Stop bein such a tight arse, its more effort than its worth sometimes
Seriously! No I wasn't being serious about drilling a hole and plugging with a tyre value, though it did actually happen. I didn't carry out the work though and to put your mind at rest the car was repaired properly when back in the UK (we were working away in France)
Hi All
Glenn
You dont live in Yorkshire by chance ????????
Seriously to even consider syphoning a few gallons of petrol out is downright tightfistedness .
And thut's fuct. :giggle:
Hahaha i'd be getting it out. I don't see a problem with wanting to save a bit of money at all! Me being frugal with things like that means I can spend money elsewhere.
elsewhere.
Do you also live in Yorkshire ?
Edited by stevensmith91
Who fills their tank full of fuel when they know it's going to be part ex'd!
It can only be about £30-£40 worth of fuel and you'd go through all that hassle just to get some fuel back out, you'd have to leave some in anyway to drive around and to get to the showroom.
I know things are a bit tight in the world but resorting to siphoning fuel, you'd think it was the 1970s during the fuel crisis.
Yes haha. Im also a student!
Ive never been a fan of stereotyping though.
No harm intended just it's a lot of bother to try and get some fuel back.
I usually take mine in with the fuel warning light on !
Besides. What do you plan on doing with the fuel if you did get it out? I certainly wouldnt put it in my new car due to the crap out the bottom of the fuel tank which could of mixed in with it.
For the sake of £30. I definitely wouldnt put that in my car
Give your car a final good blast, it will soon burn up the fuel. I had the same problem with a courtesy car I was using but as soon as I put my lead boots on the gauge soon went down. I had a Corsa SRi and in 1st gear it went to 8,500 revs and in 3rd gear it went just over 70mph. I can assure you the gauge soon went down.
why do people still think modern cars tanks contain this fabled ****e in the bottom?
back in the mid nineties maybe, these days, no chance.
Ha!  Typical student  :rofl: :rofl:
