Various items of inspection equipment
Hi there everyone
Over Christmas I had a bit of a sort out in my garage (aka shed/cave/hidey hole..)
The following items are available from my days in the inspection and calibration departments at various engineering companies.  Some of it is specialist kit, please ask if you want any more information.
All the pieces were cleaned, calibrated, lightly oiled and where possible coated in hot dip strippable coating (crocell).
They have been stored for a few years, so I will check them over before any deal is agreed.
I will give it a couple of weeks on here then put them up on other forums.
Either £50 each or please make an offer for any items you may want, either on here or by PM.
Postage is possible world wide at cost.
Regards
Paul
All this kit is my own and I have scared myself researching the prices..... but it has to go
Here you go:-
£15 Baty Plunger   DTI             0.0005” OK With magnetic base, no box
£5  Baty Plunger   DTI              0.0005” OK No box
£5  Mercer Plunger DTI            0.0005” OK No box
£5  Baty Depth gauge               0.0005” OK Flat base, no box
£15 Compac Lever   DTI           0.0001” x 0.008” Good
£20 Compac Lever   DTI           0.0001” x 0.008” Good With extra stylii
£25 Mitutoyo Anvil micrometer  0-1” Good
£10 Mitutoyo Micrometer          0-1” Good Back of anvil ground away for access
£25 Tesa Micrometer                0-1” Good
£30 Mitutoyo Micrometer          1-2” Good Back of anvil ground away for access
£30 Tesa Micrometer                1-2” Good
£30 Mitutoyo Micrometer           2-3” OK
£30 Tesa Micrometer                 2-3” Good
£20 Moore and Wright Micrometer 3-4” OK Slight rust in places
£25 Moore and Wright Micrometer 4-5” Good
£25 Moore and Wright Micrometer 5-6” OK Slight rust in places
£5  Tesa Micrometer                  6-7” Poor No box
£35 Moore and Wright Micrometer      6-12” OK
£20 Mitutoyo Micrometer                     9-10” Good No box
£5  Mitutoyo Micrometer                      0-25mm OK Box in poor condition
£30 Tesa Micrometer                           25-50mm Good
£30 Moore and Wright Micrometer      50-75mm OK
£30 Etalon Depth vernier                     12” Good
£75 Benson Gear tooth vernier           0.001” Good
£50 Mitutoyo Long jaw vernier caliper0-12”/300mm Good
£30 Mitutoyo Dial caliper                     0-300mm Good
£35 Mitutoyo Depth micrometer          0-150mm Good
£30 Moore and Wright Depth micrometer 0-6” Good
£-- Mitutoyo Diatest                          0.95-1.55mm Perfect Specialist kit! Only used once, list price £1322
£15 Mitutoyo Vee blocks                  1” OK Double vee
£10 Unknown Vee blocks                 1.5” Good No box
£35 Mitutoyo Inside micrometer        2-12” Good
£5  Mitutoyo Hole gauge set             Good, plastic case
£10 Moore and Wright Precision straight edge   OK Scruffy box
£15 Moore and Wright Precision spirit level    Poor Corrosion in places
£5  Unknown Optical parallels                  Scruffy but functional
£75 Unknown Granite surface table         8”x12” Very good With cover, grade 0
£10 Select Gauge block set E28              Poor
£-- Select Gauge block set E81               OK Wooden box, need to check condition!
£100Select Gauge block set M112          OK Stains evident on non-measuring faces
£20 Unknown Gauge block set M9          Good 1.001-1.009mm inclusive
£10 Unknown Projector graticule             OK Box in poor condition
Remember, I will check the condition before we seal the deal. :-)
I'm sure I will regret selling this stuff when I next strip an engine...
Paul
Hi everyone
I have taken some pictures and made a little webpage to avoid filling your email inbox up!
Please have a look at http://maxjephson.co.uk/equipment/.
Paul
There's some serious porn there Paul.
GLWTS.
I ran a busy inspection department where we were encouraged to buy our own kit.  When I left I went  into the calibration of equipment hence so much available.
Anyone interested?
Paul
Hi Paul,
Do you still have this kit for sale?
If so I would be very interested in talking to you regarding talking all the equipment off your hands.
Please let me know
Darren
