VCDS Options
Mine's a 57 plate MY08... go figure!
Phil
  • Replies 157
  • Views 68.8k
  • VAGCOM address 09 central electrics , long coding, long coding helper, turn signal as running light and type in a value between 0-100 this is for the brightness. I have mine at 20% and is a good brigh
  • Can we have the bits and bytes on these:)
  • What does teardrop wipe do?
Where is the controller located for this?
Sent from my Galaxy S5
Mine's only an Ambiente.
Maybe the higher spec Elegances had a different controller perhaps for additional functions (such as headlight washers) which the Ambiente doesn't have.
Yes it does and, IIRC, has a setting for Xenons with shutters (but I might not be correct on that).
Yeah the Ambiente did not come as standard with fog lights.
Phil
On the main electronics board behind the fusebox, above the pedals.
Mike
Thanks Mike
My Ambiente ('07) has fogs as standard!
Hi all,
I have a 07 octavia vrs & want the following options turned on if possible,
CH/LH lights
Twin rear fogs
Scandinavian DRLs
Large MPH display (I have maxidot display).
Selective unlocking (drivers dr 1unlock - 2unlock full car)
Just need to find some1 local-ish to Cambridge/Huntingdon.
Edited by Dubbsley
No much TBH ahm
Selective unlocking
Alarm chirps
DRL’s
CH/LH lights (providing they have been actives previously)
Can all be turn on and off in the maxidot.
How do you do this via maxidot?
Hi does anyone have vcds near spalding area to help me add both rear fogs, drls if poss & anything else that they can help with thanks in advance.
sorry forgot to say it is a Octavia vrs 2008
Edited by bell222
Whats scandinavian drls?
Can you not have sidelight set ON when ignition is on? I'd like that better.
That make sence to run sidelights all the time. I just have my indicators to 20% all the time haha
does anyone live in the derby area that could activate a few things for me on my Octavia vrs 08 ? please
I live just outside Derby and should be able to help you. Drop me a PM.
Wondered if the mirrors can be set to auto close / open when ignition switched?
Also anybody in the Hull / East Yorkshire area could help me tweak a few options?
I have a FL elegence estate
Many thanks
Paul
Can coming home/****ing off lights be set even if I dont have Maxi dot?
I'd also like the cornering fogs :)
Can the DRL's be kept brighter when the sidelights are switched on? Mine dim to about 50% and its rather annoying.
Only an hour and a bit up the road in Whitby if that's any use, Paul?
Mirrors can't be made to fold automatically without changing the mirror units to ones with motors in, and various other bits of controller and wiring changes. Be aware that the FL models are quite limited as to what you can do to them.
Mike
Hi Mike, that's a kind offer, I may have a run out to the seaside  :sun:
I do have motorised mirrors, it's just i have to remember to flick the switch to close / open manually. Would be good to get them to do it automatically.
Do you have a list of changeable options for FL models? (sorry if i've missed it in this thead)
Many thanks
Paul
  • 2 months later...
How do you set this up?
It needs to be activated on vagcom. 2 min job
Ok cool, I dont suppose u have u got a idiot proof guide to doing it?
VAGCOM address 09 central electrics , long coding, long coding helper, turn signal as running light and type in a value between 0-100 this is for the brightness. I have mine at 20% and is a good brightness. Need to get a night shot really.
C6207C4D-F630-4294-9A97-37E3F1917598_zps
VAGCOM address 09 central electrics , long coding, long coding helper, turn signal as running light and type in a value between 0-100 this is for the brightness. I have mine at 20% and is a good brightness. Need to get a night shot really.C6207C4D-F630-4294-9A97-37E3F1917598_zps
Cheers mate.
Anybody in the lincolnshire/yorkshire area that could do a few vcds tweaks for me?? I live near sleaford but spend a few odd weekends to and from Rotherham, near Sheffield :)
Looking for needle sweep, alarm chirp, twin rear fogs, teardrop wipe and maybe a couple others activating if possible :)
It's a 57 plate preFL vrs btw :)
might have a run up maybe just after the new year obviously got loads to do in the next few days :)
