VCDS Options
It only uses the horn if no alarm is fitted.
WOW! Shocking.easy to steal.
  • Replies 157
  • Views 68.8k
  • VAGCOM address 09 central electrics , long coding, long coding helper, turn signal as running light and type in a value between 0-100 this is for the brightness. I have mine at 20% and is a good brigh
  • Can we have the bits and bytes on these:)
  • What does teardrop wipe do?
Probably still have an immobiliser installed though.
  • 7 months later...
can i do this on a 06 L&K??
in fact anyone got a list of options available, I currently have anti hijack, easy entry, coming/leaving home, both rear fogs,mirror dip with reverse , hazards with emergency braking, and rain closing all enabled, is there anything I have missed and I could enable
or is that my lot???
Edited by moiloon
my above post I tried to quote the post in this thread about using indicators as drl and dimmed, can I do that on my 06 L&K ?
in fact I havnt got rain closing enabled, even though I believe all the relevant boxes are checked in vcds, just been and tried it, windows down, car locked water on screen, windows do not auto close
anyone got the correct steps to get it functioning?
thanks
Edited by moiloon
I vaguely recall that when mine was done, there was an option on the next screen that needed to be changed too. (The car went 2 days ago so I can't check) but the first screen gave the coding, the second have something about "rain closing inactive".
I'll have a look on the Scout tonight, see if I can find it again.
  • 4 months later...
No, FL only.
My list of VCDS tweaks (at least on preFL Octy)
Switch off teardrop wipe front and rear
Switch off comfort indicators
Switch off sychronised mirror adjusrtment
Switch off seat belt chime
Switch on rain closing windows
Switch on Scandinavian DRLs
Switch on anti-hijack
Switch on alarm chirps
Switch on CH/LH lights
Switch on twin rear fog lights
Switch on cornering fog lights
Alter weight of power steering (only on earlier cars)
Calibrate fuel computer
Calibrate speedometer (as much as possible)
Code for HID kit
Code for footwell lights retrofit
EDIT Code for MFSW retrofit
Mike
Can the cornering be activated on a pre-fl? I just receives my vcds cable today so please tell me how! :)
What year? Earlier than a 58 plate, probably not.
I think it's pre 57 plate. Mine is activated on an 08 although I have to say it's hardly any help.
I'm afraid I can't quite remember how it's done, but pretty sure it is somewhere in the central electronics module, and most of the changes there are quite obvious. Just remember to take a note of any codes prior to making changes so you can easily restore them.
Edited by adamal
Mine is a mid 2007. I've been through the central elec yesterday but nothing too obvious.
As above, you are on the borderline as to whether it can be done on a preFL. I can activate mine on a March 2008 build.
If you can, the coding is
Pre facelift models VCDS module 09 Central Electronics
Long Coding Helper
Byte 23 Bit 2 Internal Turn Light Algorithm Active - TICK for active, UNTICK for inactive
Byte 23 Bits 3-4 Set to 08 Turn Lights via Fog Lights
If those options are not there, you will not be able to activate the cornering lights.
I have mine switched off, I found they are useless on the Octavia, and look chavvy.
Mike
Can this be done on a 10 plate vrs estate with led drl lights
I've found that recently, when I tried to code a 56 plate Ambiente for HIDs. The Ambiente controller did not have options for xenons without shutters, but a full range of Elegance models from 54 plate to just before FL did.
Does the Ambiente have front fogs fitted?
Mike
Hi
​This is the problem that I am having - how did you overcome this?
Kaz
  • 1 year later...
On 22/12/2014 at 21:47, pip_vrs said:
VAGCOM address 09 central electrics , long coding, long coding helper, turn signal as running light and type in a value between 0-100 this is for the brightness. I have mine at 20% and is a good brightness. Need to get a night shot really.
C6207C4D-F630-4294-9A97-37E3F1917598_zps
Sorry to dray this up years later, but I can only get the turn signal as parking light to come on with light switch in pos 1 or 2 not off, is that right? I wanted them on when lights off as a running light. Any tips gratefully received.
Is there anyone around leicester with the kit and knowledge to turn some of these features on, on my  2006 vrs. Will pay you for time spent with me. Thanks
Just seen this post.  I work in Leicester and I have VCDS if you still need help.
How do you activate the large speedo on vcds as I cant seem to find it. I have a 2011 VRS  and the large display does not have it as it reads in KPH  annoying as my previous car 2011 VRS had the large speedo
Is there a way I can have the daytime running lights on with the headlights? cannot see a option for it on vcds or am I missing something?
Assuming you have a 2011 MK2 FL vrs, the drl are too bright to be used at night.
The stock behaviour is for them to remain on but dim to an appropriate level for dual use as side lights. Is that not happening or have you got a different car?
When the headlights are on the DRL's are off.   I have a 2011 Octavia vrs
So you have no sidelights on the front at all?
Might be worth posting a full VCDS autoscan as it feels like a previous owner may have tweaked something. I'm not sure you'll be able to fix it with VCDS alone either...
Edited by langers2k
Typo
I have bulbs in the headlights that don't seem to do anything little blue ones? . My headlights are fine otherwise.  I was just wondering if it was possible to have the DRL's on at the same time as the headlights?
On a standard vrs like yours, the little blue sidelights aren't used. There is no wiring to connect them, they are only there as it's the same headlight a non vrs.
Instead, what should happen is for the drl to dim to sidelight brightness.
As this isn't happening, it's likely someone has messed something up. A VCDS autoscan should rule out the more obvious reasons.
When correctly coded, the drl will remain on with the headlights and dim to remain road legal.
Found this now. Seems you were correct someone had switched them off all working ok now.
Is there any other options I can activate?
  • 7 months later...
Evening Chaps!
Not been on here for a while, but have now got myself back into the fold..
Got myself a FL 2012 vRS TDi DSG - It has the Maxidot - would love the large MPH display - is this possible?
I have OBDEleven with Pro activation.
So far I've managed...
Cornering Fogs
Dim DRL with Indicators
Disable Seatbelt Chime
Disable headlight washers - just a waste of fluid IMHO
Increased comfort ind to 5
Turned off chirp when locking/unlocking
