Removing inner rear drivers side door panel
Hi all. I have read about the door latches failing and it seems that mine has also done this, on a 2007 56 plate Octavia. I therefore need to get the door latch module out of the door to inspect and either replace or clean the micro switches. What I need to know is do I need to remove the window and all the other components to get at the door latch module. It seems that the panel which has the window winder motor attached and is sealed into the door is also riveted in. How do I remove this to get at the last h module? Cheers in advance for any help!
Cheers for the reply but the inside of this door looks nothing like mine. There's a whole other panel over the window and lock mechanism. Cheers. Ade
OP has a Mk2
i was about to say the same thing...
OP has a Mk2
Try posting the Mk2 Section, they will have details on it no doubt
