Diesel Smell
There also seems to be what is oil coming from a little hole in the EGR. It's underneath the 'spaceship' type thing. I'm going to clean it all out tonight and see what the crack is.
Just wondering if any of you had the same before?
Yes, my 'spaceship' type thing also goes wrong a lot, it's not cracked though.
same here my egr leaks abit of oil every now and then, I have scrapped out loads of thick oily deposits in the past. I would be concerned about the diesel leak and get that looked at quite soon fella.
Seepage from the egr means it's either a bit blocked up or the diaphagm has split.  You can do a vac test to check the seal.  Otherwise, just clean it out.
or the diaphragm piston seal is shot   can't easily be replaced    DON'T block up those holes
Yes just been to the local dealer and got myself a fuel filter. I had the egr mapped out at darkside but there's still probably gunk and rubbish in the pipe so i'll give it a clean out tonight.
Right guys, I found the problem.
I started the car up and could see the diesel weeping from one of the rubbish spring clips that hold on the feed pipes.
I replaced these spring clips with jubilee clips and the leak has stopped.
Cheers for the info guys, much appreciated.
