CAN interface: questionable
Hi,
I would try some vcds tweaks (really, just needle sweep) but when I test my usb port, with my friend's cable, it says "Can interface: questionable". My friend's car is an audi a3 and I have a fabia my2008.
I think that problem don't allow me to use the long coding helper menu, so i'm not able to perform the necessary steps.
And i'm not able to perform autoscan
It's a cable fault? My car doesn't support CAN interface?
thanks in advance
Edited by kekku
What cable are you using?
I'm using an hex+can to usb cable
Did you have the ignition turned on? It must be on for onboard diagnostics to be available.
Is it a genuine Ross-Tech cable? If so then you can contact them via their support page http://ross-tech.com/vag-com/support.html
Yes, I turned on ignition. Sincerely i don't know, i think it is. like i said it's not mine. i'll try. However can anyone confirm that my car is "CAN-enabled"?
Because I'm not able to perform autoscan too. I have to select manually my car's model.
Tomorrow i'll speak to my friend about ross-tech's support.
You will not be able to do the needle sweep ! Needs a certain type of clocks/speedo only a few are able to get needle sweep, you need to remove the housing that is under your clocks this will have a product code on it stating which type you have
Couldn't i retrieve it from vcds?
No ! If it's not there !
Anyhow the problem is the "questionable" grade. Is it normal? Ross-tech's site doesn't mention it. They talk about "Not Ready" or "OK" grade. I read something about radio's interference with the CAN gateway on some cars
