Stereo locked to Audio menu
Got an aftermarket ANS620 navi HU in fitted my cr170 a good while back and later a Maxidot retrofitted, too.
When going from the MFD to the Audio menu, the Maxidot completely locks itself to said menu, and cannot be changed without either fuse removal, or battery disconnection. I'm pretty sure this isn't normal, and no amount/combination of button presses unlocks it.
Thought I read certain Colombus units exhibited similar actions, but these were cured by turning the HU off and a subsequent firmware update, or something.
With no such update available for my HU that i know of, Is it something to do with canbus gateway (I have no idea what that is)?
Any ideas? These VAG electrics are completely unfamiliar to me.
Cheers
no fix, so avoid the Audio menu
Fair enough - not the end of the world, tbh.
Cheers.
Fitting a Polar FIS+ cures this problem with the Columbus.
For the Columbus there is also a fix that can be installed. Just updated to 5270 and installed the software fix and all working.
I still want a Polar Fis+ as I believe it can also get PDC displayed on the Columbus again without needing to fit OPS.
Phil
Hmm, whilst trawling an AUS VW forum, which seems to have a lot of information about these units, there seems to be a hidden menu with various CANBUS options.
Listed are: CAN-S, CAN-V, CAN-X and CAN-M (which is the current selected option).
With previous VCDS scans, I've always had the following CAN gateway error listed (since the HU was fitted). Could this be due to the wrong CAN setting in the HU?
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 Q    HW: 1K0 907 951
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K087020CCB
   Coding: E9807F060002021303
   Shop #: WSC 11679 000 1048576
   VCID: 3561C75F5CB4ADB6775-8060
2 Faults Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 116
                    Reset counter: 110
                    Mileage: 94426 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:50:09
01304 - Radio
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 14
                    Reset counter: 150
                    Mileage: 94426 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:52:02
Cheers.
