Car wont start- Octavia 1.9 Tdi Diesel 2008
Hi folks,
I can't seem to find a related post but apologies if one already exists.
I've a 2008 Octavia Est 1.9 tdi diesel. Car has 140k miles on it. Never had any major fault issues, car was fully serviced about 6 weeks ago and rear shocks were done.
Problem- car lost power mid drive for my wife a week and a half ago. Car had done a 10 minute spin about three hrs previously with no issue. She was then able to restart the car but it cut out again within 150 yards. I started the car three hours later without issue and reversed it into the driveway, not a problem.
Car towed to garage the next day. Cut out twice for mechanic when he took it from the tow truck into his garage. He had it running for the next two days and it didn't cut out. He says he had it hooked up to computer and it showed 4 main computer faults. He's not our usual mechanic as we've recently moved house. I reckon he doesn't have the proper computer and can't give full details.
I collected the car a day later and it has completed 3/4 days of short spins. Drove it for a total of two half hrs today with a break of about 2 hrs in between. On last leg of the journey light bulb warning light came on and went off about 10 mins later. We reached our destination and I turned off the car. I then began to check lights. Tried to start the car to check full beams and it now wont start. I've checked it about three times since and it wont start. Lights, locks and clock all working. Engine does not even turn over- no life whatsoever.
Sorry if I'm leaving out vital info, I've zero car knowledge. A kind uncle is going to hook it up to VAG-COM computer. I'd appreciate any help or items to look out for.
Regards,
Brando
Edited by Brando31
A poor battery can do lots of strange things to the Octavia. Might be worth checking.
Thanks for the reply. Just scanned car and VAGCOM is reporting multiple modules "Cannot be reached 1100" such as engine ECU and more.
Here's the scan log:
Saturday,11,October,2014,23:52:09:39594
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: TMBJS21Z782137816   License Plate:
Mileage: 235540km-146357mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: TMBJS21Z782137816   Mileage: 235540km/146357miles
01-Engine -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Cannot be reached 1100
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No SW: 1Z0 820 047 K    HW: 1Z0 820 047 K
   Component: Climatic PQ35   140 0909
   Revision: 00140009    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 3B75FDD37AFF0AC68EF-806E
3 Faults Found:
00819 - High Pressure Sensor (G65)
            009 - Open or Short to Ground
01316 - ABS Control Module
            004 - No Signal/Communication
01314 - Engine Control Module
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000005522188
   Coding: 00880F030004140043110D000000000000087B075C000000000000000000
   Shop #: WSC 73430 790 00000
   VCID: 6FED19837E07A666727-803A
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 190208 022  0601
   Coding: 00055223
   Shop #: WSC 73430
5 Faults Found:
00988 - Lamp for Brake Light; Right (M10)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 159
                    Mileage: 235335 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 14.25 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
02403 - Terminal 15 for Interior
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 235545 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 11.90 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01321 - Control Module for Airbags (J234)
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 235545 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 11.90 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 235545 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 11.90 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01309 - Power Steering Control Module (J500)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 235545 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 11.90 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BM    HW: 1K0 953 549 BM
   Component: J0527           051 0100
   Coding: 0000002
   VCID: 7EF334C7296DDFEEE91-802B
No fault code found.
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 902 D    HW: 1Z0 920 902 D
   Component: KOMBIINSTRUMENT VD1 1620
   Revision: V1620056    Serial number: SKZ7Z0H4704065
   Coding: 0003401
   Shop #: WSC 20067 576 90109
   VCID: 3561EBEB5CDBDCB678B-8060
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0192
   Revision:   H16       Serial number: 2500K082180A37
   Coding: E9801F060002022303
   VCID: 3467D6EF57A1C5BE4F5-8061
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1620
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         006 1204
   Coding: 0000564
   VCID: 387FE2DF4BC921DE63D-806D
1 Fault Found:
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 CN
   Component:    KSG              0401
   Coding: 81D002003F098505095B010004CC
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
1 Fault Found:
01312 - Powertrain Data Bus
            013 - Check DTC Memory
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000564
   VCID: 3979E7DB70C338D69C3-806C
1 Fault Found:
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       020 0041
   Revision: 00020000    Serial number: SKZ7Z3H0023755
   Coding: 0000200
   VCID: 2E53C487B98DEF6E391-807B
1 Fault Found:
00856 - Radio Antenna
            011 - Open Circuit - Intermittent
End   ---------------------------------------------------------------------
Edited by Brando31
Looks like a battery problem to me
Thanks for reply. We've disconnected the battery for the night and are going to try a scan again in the morning. Will post the results then. Praying it's the battery and not the ECU.
Brando
  • 3 years later...
Hi did you find a solution for this? Was it indeed the battery?
