6 or 7 speed DSG
Pipsyp, I'm not sure what the wet 6 speed is called but, the dry 7 speed DSG is called the DQ250
Speaking of the DSG gearboxes: Are there any blow up diagrams of them available online?
I'm quite curious on how the park -latch has been designed...I'm just wondering if it's sturdy enough to leave the car in park without using the handbrake (unless there's a steep incline). I don't feel comfortable using the handbrake through the winter, since we sometimes have weather that can make the brakes stick...it's something that's happened to me in some previous cars and I prefer to just leave the car in gear in the winter time if I'm parked on level ground.
I've been thinking the same thing.
Isn't the wet 6 speed called the DQ380? (I assume that's why the max torque on the 2.0 TDI is limited to exactly 380 Nm.)
EDIT: I found a pretty informative cutaway image of the DQ380:
Edited by kallekilponen
The 1,8 TSI produces 250 Nm and has the 7 speed dry clutch DSG. 1,8 TSI combined with 4x4 and DSG produces 280 Nm to compensate for the extra weight and resistance. Therefore the stronger 6 speed wet clutch DSG.
