Windows/mirrors Playing Up
Has anyone ever come across the following problem? The auto system on the windows failed and the mirrors for no reason moved themselves down and then stopped working from the switch. Got back in the car and the mirrors came down again and kept clicking on the lowermost position for 2 minutes. I lowered the drivers window to manually push the mirror back to a usable position, but the window wouldn't go back up! If I held the mirror switch up for a couple of seconds and then pulled the window switch up, it went up a couple of inches then stopped. Had to repeat the process till the window was up fully. Too scared to try the passenger window. So now I have no electric windows or mirrors. Some serious electrical fault going on there. Guessing there must be a short somewhere, but don't know where to start. :confused:
SOMEBODY PLEASE HELP!!!! :(
Assuming the fault's occured both at the same time -- sounds like a control unit fault -- maybe just a coincidence -- you could try spraying the lip in the window seal with WD40 or similar and see if that sorts the window fault -- the mirrors may be just the switch -- failing that control unit failure most likely -- is it both mirrors that drop -- or just one side -- if only one side flick the switch to the other and see if it still does it
It is both mirrors. And yes, the windows went at the same time. Was a bit worrying when I couldn't close the window! Thanks for the help. Am popping in to test drive the vRS, so migh have a word then.
Ta very much. :)
Me too -- although just for fun...not thinking of changing just yet..........
I am. Even more so now! :p Needed a good excuse to change. Trip to Jabba and a tinting shop too mefinks! :cool:
Graeme,
i've had a problem with the window switch swapping sides (left switch operates right) and refusing to work also. Mirrors packed up too.
Cured by switching off engine, locking car and opening again (ie something was reset somewhere)
Its done it a couple of times but not recently and i think other Fabia owners have reported the same. :(
Matt. I had the windows swap sides before. As you said, switch off engine, lock and unlock car, restart and all was well. This time it doesn't want to know! :( Going to see if pulling out the mirror fuse does anything. If not, hoprfully i'll only have to put up with it for a couple of months! ;)
Matt - I had the switching window switch thing - but only during that period when my turbo was going off intermittently. Once the new turbo was fitted everything has been absolutely fine. I sympathise wiht you, Graeme. Losing control of electric windows would be a nightmare for me as they're used so much.
The "switch car off, restart all being well" thing was also the case with me & the dodgy turbo, but it would just cut all boost again after about 30 seconds if I was lucky! I'm pleased to say I've had no gremlins since the turbo was replaced at 30K miles, 11000 miles ago! [fingers crossed smiley]
problem with mirrors/windows will most probably be the convience (c/locking) control unit as for the windows and mirrors swapping over i have reproduced the fault by locking vehicle with remote whilst hatch is open most probably a software glitch.
Cool. Cheers for the replies. Will probably put up with it now. Just driven a Fab vRS and WOW!! Dealer is trying to get hold of a Yellow or black one with Xenon lights for me. With a bit of luck they can get me one for the end of the month or start of October! :D Can't believe the deal they gave me. Woohoo!
:mw:
Excellent Graeme!
I somehow knew you'd go for a yellow one! :D
Can you get the Xenon lights on the UK spec ones, as you cant get them on the Octy which is a shame.
:cool:
Originally posted by FabiaTDi in this post
Excellent Graeme!
:cool:
You can indeed. It's a factory option, but not many coming over. You have to have them with headlight washers. There is only one Yellow one coming over this month and that's the one he is trying to get hold of! 12,500 for vRS with xenons. 5,800 for mine and 3,500 left to finance on the 16v. Worked out to about 250 a month for 4 years.
Thats just a rough estimate. Could have less finance to pay, so might be cheaper. :cool: I can't wait now! :D
Oddly, I had a slightly different problem with my driver's door window yesterday. For some reason moving the button in the direction to make the window close made it open further. It then wouldn't close whichever way I moved the button. Getting out of the car, locking and unlocking it a few times and then closing the window with the key seemed to work. It's been OK since.
Have ahd a similar problem after the battery died. Turned off, locked (and held the key in the lock to re-set the window up stops), unlocked (and held the key to reset the window down stops), and all is now fine!
Cheers!
Will try the key in the door to reset and see what happens. Cheers guys. As said earlier. Not too fussed now. Just an inconvenience having to use the a/c and losing the fuel economy slightly!:rolleyes:
Graeme,
Just wondering if you are taking your Fab back to standard for the part ex.
Asked about that. The answer was that if I can't get it all atandard, then supply the remaining origional parts and they will do it. So I will put the steelies and the filter housing back on and leave them the zaust and springs to do themselves! ;)
