Mk1 2003 1,9 SDI Correct battery
Hi Guys,
I have searched and can't find this info.
I will be off to France soon for a few months and am just getting the car ready, It may need a new battery, but what is the correct one? on Tayna batterys it says 750 cca, some other sites say 640 cca so what is the factory fit one ?
Steve
  • Sponsor
As far as I've seen, ETKA doesn't specify CCA, only Ah for 'genuine' batteries.  What's fitted on the production line probably varies month by month depending on suppliers' prices/discounts. As such it may not be a consistent set of ratings, other than probably the Amp-hour one.  Sorry I can't be more helpful.
Edit: sorry, I'd mis-remembered and spoken pile of BS above:
Here's what the options are for a 2003 Fab:
MODEL DATA     battery
battery cover
fuse socket         Teilenummer battery
battery cover       1 000915105DA battery with charge state indicator, filled and charged 36AH/175A 1   (1) 000915105DB battery with charge state indicator, filled and charged 44AH/220A 1   (1) JZW915105C 44AH/200A 1   (1) 000915105DE battery with charge state indicator, filled and charged 61AH/330A 1   (1) JZW915105 61AH/330A 1   (1) 000915105DG battery with charge state indicator, filled and charged 72AH/380A 1   (1) JZW915105A 72AH/380A 1
As you can see, Amp-hour ratings and what I assume to be CCA ratings are included, and the latter are all much lower than what your site suggests , so either should be well capable.  The formatting's gone awry in that list, go here to see it clearer.
