so I got my vcds and had a play
Been looking at buying one for ages and finally got one
So far I have programmed
Needle sweep with ign
All doors unlock with one blip
Auto locking
Teardrop wipe
I read that if I change to Australia it changes the km display to miles per hour I don't have maxidot but looking at getting one
Anything else worth programming ??
I'd like to have full control of the rear wiper, ie sometimes I want it on continuously.
I`m certainly going to have to get this sorted out on mine, unlocking all doors on one blip would be the greatest step forward...Its the single biggest dislike of an otherwise great car
MPH display requires maxidot.
You got fog lights?
Phil
No fogs
Trying to source a cluster for maxidot
Am I right in thinking any later fabia or roomster will fit as long as the led is in the same place on the key
I would love a needle sweep start on mine! how much was your vcds?
£279 including a case
If your not too far nip over
Sorry I'm on mobile so can't see locations
  • 11 months later...
I had a fiddle with VCDS too
Didn't have the option to active needle sweep which is shame but no biggie
Activated 4 door opening with one click, auto locking and tear drop wipe but have no ide what it is haha
Also ativated coming home and leaving home lights but nothing has changed, handy feature on my mk5 golf gti so would like it to work, is this only available on Xenons ? I only have standard headlights in my scout
Lots of stuff became accessible after 2008, prior to that can bus protocol was 1.6 ... no access to needle sweep implies yours is pre-2008?
Edited by b1ackb1rd
It's called something like celebration
It's 2013
I've checked and double checked but it's definitely missing. Odd
I'll check mine tonight
On older cars it's called "staging" and on newer cars it's "indication celebration".
Sent from my D5803 using Tapatalk
It's 2013
Compared to my Touran I can access very little via VCDS on my 2007 Scout, I can't see this either.
Have you got the latest Ross Tech software?
The Roomster, being based on the mkI Fabia is more limited than other cars of the same period but based on newer designs. The Roomster isn't full can bus unlike the Touran.
Auto locking
Teardrop wipe
Wow - Can I get "One Blip" unlocking on mine ??? 1.2 TSi DSG 2013
Questions ?
Needle sweep with ign - Is that a burst of activity with IGN On ?
All doors unlock with one blip - Must Have !!!
Auto locking - ???? How does that work ????
Teardrop wipe - ???? No Idea ????
Please post any other great things that can be done as this is really interesting to find out about . . .
Edited by petrev
Tear drop wipe is when put your washers on and the wipers go you get an additional wipe 5 secs later to prevent the usual tear drop of water down the screen
Auto lock locks the doors once a certain speed I think 10 mph is reached
Tried this but turned it off after it ****ed me off
Auto lock and unlock are useful if you have a youngster who looks to leg it every time the car stops - I'm not mad on child locks
I turned off the tear drop wipe as it leaves a smear if you use an alcohol based screen wash.
Can anyone tell me if it's possible to activate the needle celebration on a 2007 model?
Found indication celebrations under instruments > adaptions but get an error message when trying to activate
Wondering if it's worth the hassle haha
Try staging instead.
I did try both but got the same error message. Never mind, I'm sure I can live without it
I was under the impression for safety reasons the door cam still be opened from the inside
You need to pull the handle twice to open the door.
Never knew that thanks
