Smartgate connectivity
How do I connect to it (i.e.know if I have it).
It was supposed to be on order, really unsure how to commence setup.
Just start the car and check for Wi-Fi networks with your phone. It should show up if you have it. (The network password is your VIN)
I tried that...but nothing showed. Part of me thinks it was not installed.
Btw what was the network name called?
Stupid question is the car WIFI always on (or is there a way it needs to be enabled to broadcast?)
Smartgate Wifi is always on when the ignition is on.
Depending on the firmware version it will either show as SmartGate_VIN, or DIRECT_Smartate_VIN - where VIN is your full VIN number
Thanks, I did try it in showroom but there were a lot of WIFI spots showing, none mentioned Smartgate.
I reakon it wasn't installed on my car. The dealer said he would get it installed if need be.
What is the main reason for you guys go install SG?
Another toy to play with. The deal I done included it.
Is it an option. Didn't see it
