Tpm
Sad555
Getting back to the TPM, I was wanting to know which version of firmware on the YETI 5L would let me use the Maxidot to reset the TPM settings.
Anyway I got Automotive Gadgets in Huddersfield to fit the reset button and the wiring to the ABS block, the VCDS could not be set up for the Maxidot but the standard setup worked as described in the Yeti manual, so all ok.
Cost £80 for fitting and setup.  :cocktail:
  • 3 years later...
Hello!
Following the instruction I found here, I tried to enable TPMS function on my Yeti 1.6 TDI 2014 FL.
These are modifies I operated with VCDS:
[03-ABS Brakes] > [Coding-07] > [Long Coding Helper] > Byte 16 > Bit 2: “Tire Press Monitoring (TPMS/PR-7K6) installled”; Bit 1: it's hidden so I changed the second value (counting from right) from 0 to 1 on Binary field
[03-ABS Brakes] > [Coding-07] > [Long Coding Helper] > Byte 17 > Bit 2: “Tire Pressure Monitoring (TPMS/PR-7K6) via Instrument Cluser (MY 2011+)”
[19-Can Gateway] > [Installation List] > “4C-Tire Pressure II”
[17-Instruments] > [Coding-07] > [Long Coding Helper] > Byte 02 > Bit 0: “Tire Pressure Monitoring (TPMS) active/installed”
The result was that I had Tyre Monitor entry on Maxidot but when I try to save the "new" pressure I got the message "Could not store tyre pressures".
In addition I noticed that the TPMS lamp on instrument panel never light on.
I did an Autoscan with VCDS getting these errors from ABS:
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: 913F200E092405FA890B04EB901EA051A70C0020
   Shop #: WSC 33361 790 00056
   VCID: 7EF9A33AE9F77CBFE3-802A
2 Faults Found:
03243 - Indicator Lamp for Auto-Hold
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 134
                    Mileage: 159464 km
                    Time Indication: 0
                    Date: 2014.06.02
                    Time: 11:23:23
             Freeze Frame:
                    Count: 3
                    Count: 2
                    Count: 4608
                    Count: 4410
                    Count: 44288
                    Count: 257
                    Count: 255
                    Count: 0
00473 - Control Module for Elect. Park/Hand Brake (J540)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 134
                    Mileage: 159464 km
                    Time Indication: 0
                    Date: 2014.06.02
                    Time: 11:23:40
             Freeze Frame:
                    Count: 0
                    Count: 2
                    Count: 4608
                    Count: 8260
                    Count: 44288
                    Count: 257
                    Count: 255
                    Count: 0
and this:
4C-Tire Pressure II -- Status: Sporadic communication error 1000
After that I undid the changes made and all the faults disappeared.
Do you have any suggestion?
Ciao :)
On 04/11/2016 at 09:50, langers2k said:
I can confirm it works on my MY12 Octavia, looks like it became possible on at least some MY11 vehicles.
03-ABS Brakes
- Checked byte 16, bit 1 - No description <-- Edit: I missed this originally but it is needed as per http://www.briskoda.net/forums/topic/363554-tpm/#entry4747407
- Checked byte 16, bit 2 - Tire Press Monitoring (TPMS/PR-7K6) installled
- Checked byte 17, bit 2 - Tire Pressure Monitoring (TPMS/PR-7K6) via Instrument Cluser (MY 2011+)
19-CAN Gateway
- Added 4C (Tire Pressure II) to the installation list
17-Instruments
- Checked byte 2, bit 0 - Tire Pressure Monitoring (TPMS) active/installed
There is now a 'Tyre Pressure' section in the 'Settings' on the Maxidot:
%7BfileStore.core_Attachment%7D/monthly_11_2016/post-121621-0-32541300-1478252918_thumb.jpg
Which gives the following prompts:
%7BfileStore.core_Attachment%7D/monthly_11_2016/post-121621-0-15560800-1478252924_thumb.jpg
%7BfileStore.core_Attachment%7D/monthly_11_2016/post-121621-0-24988200-1478252928_thumb.jpg
%7BfileStore.core_Attachment%7D/monthly_11_2016/post-121621-0-91586100-1478252931_thumb.jpg
Simples ;)
Thanks very much for this, I successfully enabled it yesterday on my grandads 2012 Yeti Elegance as it has the MK60EC1. I was unable to access address 4C (Tyre Pressure II) with VCDS as it just times out, is this normal behaviour what with it being a virtual module?
Unfortunately the Mrs 2012 Octavia has the MK70, so this doesn't work, and I can't really justify swapping it for the better one as she won't have any idea what ESP or ASR is, so I've ordered the TPMS reset button and wiring kit from AliExpress for under a tenner.
That's correct, 4C is a 'virtual' module created by the ABS module so it doesn't really do much diagnostics wise.
Fitting a TPMS button is much easier than a MK70 to MK60EC1 swap so that's definitely the simpler plan! A MK70 already supports ASR too :thumbup:
  • 2 years later...
Hi Langers,
I really appreciate all Your knowledge, and hope you can guide me as well.
I have an octavia from 06-2010, with both instrument cluster and gateway replacement. (I have fitted HBA, and it works like a charm).
But for some reson i cannot get the instrument to appear with the "Tire Pressure" menu in the maxidot, so that i can reset the TPMS that way.
I have done all the coding you have described, incl. the hidden bit 1 of byte 16 in the abs module.
Im frustrated that it will not show - i don't get any errorcodes.
Do you think that i should try to soft reset the modules, or is it a waste of time ?
Do you know which wersions of hard an software is required ?
My instrument is as follows:
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 1Z0 920 803 K    HW: 1Z0 920 803 K
   Component: KOMBI         H04 0405
   Serial number: 00000000000000
And the gate way:
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 241010F1001858
BR
Mikkel
On 06/09/2023 at 11:56, langers2k said:
Can you post a full autoscan?
Yes it comes here :)
Friday,08,September,2023,21:45:02:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.3.1.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: TMBCM61Z9B2015010   License Plate:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 15 16 17 19 20 25 42 44 46 4C 52 56 62 69 72
VIN: TMBCM61Z9B2015010   Mileage: 176250km-109516miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 F    HW: 03F 906 070 F
   Component: SIMOS10.10H03 9837
   Revision: --------    Serial number:                CVN: DC322491
   Coding: 001900D6232400080000
   Shop #: WSC 73430 031 00999
   ASAM Dataset: EV_ECM12TFS02103F906070F 003011
   ROD: EV_ECM12TFS02103F906070BF_003.rod
   VCID: 2541449324E10FA79C-8070
   VINID: 91D49374606A252080045001000AE9936D
No fault code found.
Readiness: 0000 0000
   Part No SW: 1K0 907 379 AS    HW: 1K0 907 379 AS
   Component: ESP MK60EC1   H30 0105
   Revision: 00H30001
   Coding: 113B201C092300FF880B04E590190040360600
   Shop #: WSC 00046 123 12345
   VCID: 03053A0B82151197D2-8056
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 AS    HW: 3T0 907 044 AS
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000000002
   Shop #: WSC 73430 790 00999
   ASAM Dataset: EV_Climatronic A01006
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 03053A0B8A151197D2-8056
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AD
   Coding: 40180AB8E02128C040980088110081E0427900AE52758D60630440200040
   VCID: 387F9DE78B53824F37-806C
   Subsystem 1 - Part No: 1Z1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 13061  22  0601
   Coding: 00DF97
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 150610 05  54  0403
   Coding: 0730ED
2 Faults Found:
02746 - Bulb for Daytime Running Light; Right
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 2
                    Fault Frequency: 44
                    Reset counter: 81
                    Mileage: 175966 km
                    Time Indication: 0
                    Date: 2017.12.24
                    Time: 18:01:56
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.25 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 41
                    Mileage: 176251 km
                    Time Indication: 0
                    Date: 2018.01.29
                    Time: 21:39:30
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.80 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2MNU2%
   Coding: 0020790
   VCID: 3D718CF36471A767E4-8068
   Subsystem 1 - Serial number: 6332MSME54416B136
   Subsystem 2 - Serial number: 6342MSME547460356
   Subsystem 3 - Serial number: 6351HSME22284164$
   Subsystem 4 - Serial number: 6361HSME2228436C7
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 5K0 953 521 BL    HW: 5K0 953 569 C
   Component: LENKS.MODUL   009 0136
   Revision: FF010036    Serial number: 20100617301141
   Coding: 5080140000
   Shop #: WSC 00385 442 95158
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 77FD5EDBCECD4D37FE-8022
   Part No SW: 1Z0 920 843 K    HW: 1Z0 920 843 K
   Component: KOMBI         H20 0420
   Coding: 110B01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
   VCID: 408FF507DB83CA8F8F-8014
   Coding: 351302
   Shop #: WSC 00028 028 00001
   VCID: 3467A9D7973B662F1B-8060
Address 20: High Beam Assist. (J844)       Labels:. 8K0-857-511.clb
   Part No SW: 5K0 857 511 C    HW: 8P0 857 511 C
   Component: FLA           H04 0006
   Revision: AA001002
   Coding: 0101196B74745D545420363E00
   Shop #: WSC 01324 020 00200
   VCID: 2E53BBBF79174CFF6D-807A
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H20 0420
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6ADB77AF8D7FE0DF71-803E
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2113
   Coding: 0004342
   Shop #: WSC 73430 790 00083
   VCID: 76E353DF01C7343FE5-8022
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 67     3001
   Revision: 00H17000
   VCID: 3169A0C3A829530770-8064
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Component: Tuer-SG         009 2119
   Coding: 0004342
   VCID: 489FED273BB3F2CF47-801C
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 161 M    HW: 1Z0 035 161 M
   Component: Radio-SWING   002 0003
   Revision: -----04S    Serial number: SKZ4Z2M1215287
   Coding: 050004000001
   Shop #: WSC 33361 790 00999
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012563
   VCID: 326BAFCFAD2F681F09-8066
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: Anhaenger     H09 0100
   Revision: 3A001001    Serial number: 00008200737972
   Coding: 0100000100000000
   VCID: 306FA5C763235A0F7F-8064
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 3365AACB5235611702-8066
1 Fault Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
            008 - Implausible Signal - Intermittent
End-------------------------(Elapsed Time: 02:11)--------------------------
Your coding looks OK from what I can tell.
Looking back at when I had this enabled, I had the following modules:
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 943 Q    HW: 1Z0 920 943 S
   Component: KOMBI         H05 0608
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 BG    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1674
I'm afraid I'm not sure which of your modules is causing your issues 😞
At a guess, it might be the cluster which needs to be running 06xx.
Ok thanks for looking :)
But is it not strange that the cluster works with the HBA then ? It has the correct symbol with the "A" in a light when it is enabled. HBA is rather new - get my point ?
The cluster is also capable of displaying the symbol for coffee break - driver alert - so i guess it cannot be that old ?
The tpms functionality is OK - i can reset the tpms with vcds and the chime goes off - so its just the reset from the maxidot i miss....
When i installed the HBA i read a post written by you where you stated to fill the 09 module with zero's, an then afterwards the correct long coding , for the module to behave correctly.
Could it be the same with this problem ?
Being able to support one feature has little to do with the support for another.
A quick google found this thread which also implies 04xx clusters are too old for this 😞
https://forum.skoda-club.ru/viewtopic.php?f=99&t=106491
Via google translate:
Quote
Attention!
At the moment, it is known for certain that support for the “Tire Pressure Monitoring” menu item in MaxiDot begins with dashboards with number ...843 Q and higher.
!!! If your dashboard version ( ...843 F/K) or lower, then there will be no menu item in MaxiDot - NO SUPPORT at the software level!!!
What year did Skoda stop putting that on the Yeti MFD?
Mine is very early 2015 and has nothing on the Maxidot relating to TPMS, reset only by pressing the TPMS button for a few seconds when in alarm.
I dont know - but if You have a button on the dash You can press, then there is no reason to have the option in the MFD as well.
My problem is that i dont have i button to press, and therefore only can reset the tpms by hooking up the pc and vcds - so for me the option in the MFD would be very nice.
But i guess i have to install the button - but it is almost impossible to route the single wire out in the engine bay to the ABS module.
