Rob's Ur Quattro
I sorted the wiper - needed a nut tightening :D :D
New GPS is in and working.
38849826_1447128305387461_21784883511898
And I found that you can get an 82-litre tub in a quattro :)
39074818_1448939488539676_87278584043300
Waiting for a new locking actuator to arrive before I take the driver's door apart.
As for the start issue - it isn't gone but it has improved. The GPS must have been stealing voltage as the crank voltage has gone up from 9ish to 11ish volts and it seems more willing to start most times. The one time it failed I was able to turn it off/on/off/on and each time I heard the solenoid click, then the fourth attempt it fired, so as well as the voltage it seems the starter itself is faulty after all. I know several people had suggested that before :D I can get a brand new starter and solenoid on Ebay for about $250, or pull this one out and get it refurbished. No idea what that would cost.
I have weirdness with the brakes again. Sounds like what the garage described before bleeding the power steering, which fixed it that time.
It felt like it was applying pressure to one side then the other, and a hard almost a pulsing feel to the pedal, then I lifted off and braked again and it was fine.
This happened several times during a short drive.
Could the pressure accumulator be the fault after all? It shouldn't need re-bleeding after 550 miles.
  • Replies 1.7k
  • Views 175.2k
  • Went to the supermarket while I waited for traffic to die down a bit. Second supermarket car park of the evening. Terrible pic, it was getting dark The drive home was uneventful. L
  • RobClubley
    RobClubley
    Back on its wheels at last!
  • Wento for a quick trip to the petrol station. Got sidetracked. I am loving this car! It sounds like it's gargling on the fuel not just drinking it, what an awesome sound!
Has yours got ABS and a brake proportioning valve on the master cylinder or is your spec different in some way Rob?.
I has ABS and the valve yes.
Are the people who bled the brakes for you reasonably certain that the proportioning valve is working without errors?.
Failed accumulators can give that type of issue, but usually when they go, they stay gone rather than intermitent, as they contain a vacuum chamber inside which normally fails.
That's a good point, it only happens on light braking and it intermittent.
Going to drop it to them later this week as I want a proper mechanic looking at brakes :)I'll get them to check the valve.
School dropoff on the way to Wellington European.
39169617_1455103067923318_20461518704051
Of course the brakes functioned completely normally today. Have asked for a WoF too. fingers crossed.
Got the car back. WoF failed but they didn't have time to look at the braking issue!
After fixing the driver's door central locking (I hadn't clicked a wire connector together properly and it had worked loose) I started thinking about improving the audio setup.
I know there are other things to fix but I've been pondering this for a while. I have the tape deck feeding into an Out of Sight Audio Mk3, which acts as an amp for the speakers as well as feeding the sub amp via an RCA cable (with a level control to adjust the bass). But Bluetooth music volume is only controllable by the phone's controls. So I wanted to add an amp for the speakers, with another volume knob. I came across this really neat little 4 channel amp at Repco which would fit nicely, and bought another level control and some RCA cables from Jaycar Electronics. I pulled the car apart and re-ran all of the speaker wires to the rear left where my sub amp lives, then ran the new RCA cables. Then I got the new amp out ready to work out how to secure it in there, and realised that it has two inputs rather than an input and output. So I'll need an RCA splitter to feed both amps. Or I could use the sub amp as a primary (it has an output) but I'd lose the separate bass control.
39336447_1458980047535620_92131567663788
39467559_1458979927535632_85519872846295
39522321_1458980017535623_77902521486666
39396363_1458979887535636_11574960828637
Need to work out what to do with this :)
39514688_1458979914202300_49699734615700
After a lot of swearing and a few more visits to buy cables and adapters I've simplified things a bit and ditched the extra level controller. The only RCA splitters I could get were simple cables with an extra end, and connecting those to two level controls didn't go well
So I'm feeding the Bluetooth unit to the sub amp then outputting to the speaker amp. Which itself needed an RCA splitter to convert one input to two as it's two separate amps with no built-in option to bridge the inputs.
Just need to get the car put back together now.
Drove Rusty back to Wellington European for them to do the brakes today.
The stereo is much improved, and way louder than it was. Very happy with that.
The tape deck no longer plays out of the speakers though so I have that to fix.
And the horn has stopped working. Sigh.
I've decided that Rusty is like a Tesla in that it downloads new "features" overnight.
Could this be the reason Rusty is so hard to fill with fuel? It's the breather from the fuel tank and looks like it has been pinched under the tank at some point. Need to get underneath and work out where it goes, then replace it.
39603162_1463315137102111_91448004291277
Also, standard school run pic.
39622253_1463318057101819_35071246945222
A pinched breather could indeed cause slow filling, and possibly even cause fuel starvation under sustained high throttle running.
39916170_10156393405845977_9953421867635
So, my brakes again. I have an intermittent issue under light braking where the pedal is hard and the car pulls left, then right with minimal actual braking. Come off the brake and back on and it brakes normally.
Obviously this is a little disconcerting when braking is needed.
WEEU have bled the brakes and power steering again, no air was apparent in either system. They've suggested that the front/rear proportioning valve could be at fault.
According to my diagrams it's part 803 612 303 which is about $500 here in NZ.
Oh and my ABS doesn't appear to be functioning either. Sigh.
Also this arrived:
39777256_1464930620273896_26992275979543
New starter is in!
40022348_1469643419802616_71083636544870
40030517_1469643526469272_25613408297172
I thought I'd cracked it after about 15-20 successful starts in a row.
Then I went for a drive, and as soon as the car was hot, the issue returned. Sigh.
At least I got some nice sunny day photos.
40058955_1471234459643512_27232034024807
40058950_1471282002972091_46404749866439
40159021_1471281946305430_51639529364846
40045865_1471281982972093_20168774549199
40110894_1472038399563118_92106379226786
40161387_1472038372896454_88868442466534
40172279_1472038356229789_87678134628825
Shame the staring isn't quite sorted yet Rob, but like you say..... nice photos! B)
Rob, I may be "teaching my granny" here, but have you checked the joints on the starter cables?
I've checked everything except the wires from the ignition to the starter solenoid. They go under the dash to the main fuse box then around the engine bay. I've replaced part of that run with new, but not all of it. Yet.
I got blocked in...
40411096_1476366735796951_31997364793077
40388885_1476366819130276_31726929772103
But it was worth it to hear it fire up.
Also this.
40451953_1476370872463204_22081744135205
Typical Audi parking? Or pushed there after refusing to start at a petrol station?
Take a guess.
40455446_1477416559025302_20579001049032
After about 15 minutes, attempt number 75 ish turned the starter and we were off!
The starter now has its little blanket to protect from exhaust heat.
40507090_1478381705595454_61066967160633
I replaced the wire from alternator to starter too as it looked dodgy.
40498815_1478381755595449_34285806347154
Then my daughter added pandas.
40523281_1478424442257847_33970949252532
Panda! Want PANDA!!!!
Good for 10kW per panda, apparently.
40535879_1478765325557092_78048054821404
Wants lots of Pandas!!!!!!!!
PANDA POWER!!!!!!
Edited by Lady Elanore
What about meerkats?
40504688_10156420243165977_8061188508288
Do Meerkats help traction? If so can I have 40 Pandas and 7 Meerkats please
