Rob's Ur Quattro
Finally sorted that check strap. I buggered the rivet when removing it so a bolt will do for now.
36959730_1399337260166566_46307173921781
36919702_1399337410166551_41880474738952
  • Replies 1.7k
  • Views 175.4k
  • Went to the supermarket while I waited for traffic to die down a bit. Second supermarket car park of the evening. Terrible pic, it was getting dark The drive home was uneventful. L
  • RobClubley
    RobClubley
    Back on its wheels at last!
  • Wento for a quick trip to the petrol station. Got sidetracked. I am loving this car! It sounds like it's gargling on the fuel not just drinking it, what an awesome sound!
@RobClubley - That "bolt" is a domed head set screw! ;) If that's a nyloc nut under it, then it should last out indefinitely given copaslip or white lithium grease treatments for weatherproofing.
I stand corrected. It is a nyloc nut :D
The pinstripes are back.
36983686_1400888206678138_35062883656054
Odometer is visible again.
37097600_1403453223088303_75982057698125
Quick wash for the meet tonight then when I set off, the noise from the suspension worried me enough that I turned back. I've gone over every bolt in the front suspension and most of the rear but not the top mounts so they're my next place to check.
37038474_1403466043087021_26755839103640
Also I found out where it's leaking - from between two pieces of metal where the back corner was repaired. Obviously something was not done properly.
Edited by RobClubley
Three years ago, this happened...
37387632_1409262362507389_42893672513515
I spent most of yesterday doing things on Rusty, but I don't feel like I made any progress in actually fixing anything.
About halfway through the day, the involuntary horn issue re-appeared!
37581565_1413840145382944_41769957456535
Somehow the screw at the bottom has snapped, vibrated out and made contact with the horn slip ring. Causing random beeps when steering.
37635133_1413851128715179_70995212831922
Then there was the intermittent starting issue. Left it ten minutes, no joy. Left it another ten, fired up fine.
Video: https://www.facebook.com/ProjectRustyquattro/videos/1413868148713477/
I pulled the carpet back, to check out the main power wiring.
37590480_1414013662032259_78896676020483
It actually looks decent.
37591147_1414013995365559_10616766295053
My "helper"
37396637_1414014335365525_42233951449356
I replaced the third engine earth (now that I've located it :D )
37575198_1414008922032733_18387736866649
It seemed to slightly improve the drop in voltage on cranking. But the issue is still there. Next step I think will be to completely replace the wire from ignition to starter as apparently it takes a somewhat circuitous route.
Then there's the suspension clonking, which concerns me. I jacked up the car and checked everything and it all seems tight.
Took Rusty to a local tyre place and we had a good look over the underside, swung off the suspension. All we could hear underneath was a creak from one of the rear wishbone bushes.
37642116_1414250548675237_83316065684370
But it's more of a "something is loose" noise. Hoping to have time today to drop the suspension and check the top mounts and other bits I can't see.
I have a weekend in Taupo booked next weekend with the family and I really want to take Rusty. At the moment it's not looking good.
The pouring rain provided some more leak testing. The boot is leaking in two places at opposite corners - behind the wheel arch and behind the right rear light.
I also need to fix the holes causing a leak above the driver's footwell. That has been on the list for ages, but I need to get onto it now I'm driving the car.
37551924_1414315878668704_44444915229387
So lots to do, and nothing fixed yet!
37426829_1414332088667083_24262400049015
At the shops, refusing to start. The exact same thing happened in the same place last time too. And both times, leaving the car for a while fixed it. So random.
37646413_1415104708589821_10078108418960
I had a Pug 309gti which had intermitent starting problems. It spent months at Peugeot and it never faulted with them yet every time I took it home or parked at the train station (only certain spaces) it would be a pig to start.
It turned out to be if the car was parked on a slant (Left side lower than the right) it was just enough for an earth cable (I think) to move enough for it to not provide a circuit.  It took the best part of over 1 year to work this out.
Keep plugging away, you will work it out.
I may have posted this before, but my Dad had a similar "random horn" issue with a 1970 VW Type 1. It turned out to be a broken return spring behind the centre boss of the horn push.
It stood out on the morning school run.
37633130_1418491134917845_89616730867346
I really need to spend a day concentrating on nothing but the electrics and starter. Just need to balance that with family and stuff, this is always my challenge!
As for the suspension:
37677295_1418548561578769_51013973047540
 It is something relatively simple, but it's not a simple fix. The cap that holds the strut insert in place (silver bit on this photo) has come loose on each shock, allowing the cartridge to rattle around. Which is a bad thing!
17359407_990595597707403_555494212893835
Unfortunately this needs a special tool making, and means all four struts need to come out so that the tool can fit inside the spring. Bugger.
I can't see the strut piccie Rob to give any thoughts, but in the past, I have used an adjustable "c" spanner to get the caps tight on struts with removable inserts.
Not sure if you could do that on your type, perhaps you could get the piccie working?.
At the end of the day it is just time rather than money, so hopefully not too big an issue in the overall plan of stuff.
Fixed the photo. Well I can see it anyway :)
Picking Rusty up today to fix myself. I can't really justify hundreds of dollars in labour for a job I can do myself, just to get the car ready for this weekend.
Assuming all the strut caps are the same, the adjustable "c" spanner should work through the spring coils unless it has to be done up to many stupid hundred N/ms of torque.
A motorcycle dealer could be your first call if you know the rough diameter of the strut cap, as they use many adjustment caps that require c spanners. I would slide a length of tube over the handle to get your tightening force.
Thanks for that. The instructions say 130Nm and mention a "special wrench" which doesn't seem to be referenced anywhere by part number or description.
I found this, which might be it!
I've emailed Bilstein Germany, hope I get a response.
Well, the "Bilstein special tool" looks like a C spanner at one end, although I'm not sure what the other end does.
Yep. The other end is like a coilover adjuster.
Yep, as Ken said, looks like a fixed diameter version of my adjustable spanner.
Why not get a cheapish unit from a local toolstore to do the job you need right now, then you could order the correct tool from Germany to arrive without any panic.
For some reason this is my most liked Instagram photo ever:
37763454_1420507381382887_56369749247918
So anyway that suspension. Got the car up on stands, and found that the front right and rear left caps were loose.
38405529_1435833169850308_83225914793273
I bought a 52mm C spanner and used that to tighten them up. Worth a shot before taking all of the suspension out. After a 40km test drive we still have no rattles, so time will tell.
I pulled the rear light out...
38457984_1436175603149398_71388987717226
And there's a hairline crack between the metal panels.
38511586_1436175703149388_51680814866827
Some silicone sealant seems to have sorted the leak.
38468022_1436175853149373_90299233425885
At the other side there was a hole where the new boot floor piece was welded in. This may only be a temporary fix but I have sealed it with some body filler :)
38454799_1437382003028758_54516115837697
Some driveway shots :D
38411999_1437587613008197_36934036237875
38474472_1437587639674861_43987945226082
[imghttps://scontent.fakl1-2.fna.fbcdn.net/v/t1.0-9/38512899_1437587569674868_5887504808163672064_o.jpg?_nc_cat=0&oh=52c887d79599f4c6f5227cd9c603ff29&oe=5C0DB6AB][/img]
38600496_1437587673008191_78007622471725
And true to form, during my test drive I noticed the front indicator isn't working, rear wiper has somehow loosened so it doesn't work, and the driver's door central locking motor has stopped working. Sigh. And even though the car started fine with 20% battery when I set off, and again before I returned, it would not start to move from the drive to the garage. I left it for a couple of hours and it sorted itself out. Really need to spend more time on that issue.
38528939_1439433542823604_35062623810533
I noticed my front indicator wasn't working, had to take the headlight out to get to the back of the indicator to check the wiring. I managed to drop a screw into the void of doom, never to be seen again, then got the light fixed, headlight back in, the last screw I put in snapped the metal clip it screws into, had to take it all out again to fix that. Old car life I guess!
I wonder how long it has been out. That bus driver who called me a ****er for not indicating at a roundabout may have had had a point.
Right, that battery drain issue.
Starting with the factory fuse box. The fuses for flasher unit, hazards, horn, brake lights, stereo, dome and boot lights, voice unit, central locking, mirrors, cigarette lighter are all live with the ignition off, as you'd expect.
38647226_1440954776004814_25382771087407
I pulled out all of these fuses for these to see what happened overnight.
Almost everything I've added to the car is on switched live, but (assuming the battery monitor is accurate) something was draining it even faster. I thought maybe the alarm trying to go off. It went down 23% overnight.
In the morning I pulled the power out of the (no longer working) GPS tracker. Battery was reading 52%. This was the reading after 10 hours.
38852874_1442496895850602_60797813070705
And overnight it went down by 1%.
Looks like that little thing was somehow eating rather a lot from my new big fat battery.
New GPS tracker is ordered. I've gone for this one
https://drivingsound.co.nz/product/mongoose-pt890-gps-tracker/
which looks more convincing than the cheap AliExpress/Ebay one I had previously, and it has a useful phone app.
Next jobs:
Fit new GPS.
Driver door central locking motor not working
Rear wiper not wiping, but motor is turning.
And of course that starting issue!!
I fixed the rear wiper - just had to tighten the nut a bit :D I like the simple ones.
Pulled the old GPS out, and I took a look at the heater control that isn't switching from hot to cold, and nothing's holding the outer sheath of the cable in place. it looks like a bit might be missing/broken at the back. I really don't want to take half the dash apart to look at it properly, so a few cable ties have sorted it for now. One day I will have to strip the dash apart again and fix a few things more properly.
38772085_1444276555672636_27053268423566
