Rob's Ur Quattro
  • Replies 1.7k
  • Views 177.8k
  • Went to the supermarket while I waited for traffic to die down a bit. Second supermarket car park of the evening. Terrible pic, it was getting dark The drive home was uneventful. L
  • RobClubley
    RobClubley
    Back on its wheels at last!
  • Wento for a quick trip to the petrol station. Got sidetracked. I am loving this car! It sounds like it's gargling on the fuel not just drinking it, what an awesome sound!
Crikey. It's easy to forget how bad it was!
Car park side shot :)
49043065_1611019342331689_11790918570328
Now if only you could have got the tyres at the same point of rotation :D
Is this your car jack? :)
This is a useful thing. Makes it so much easier to turn off the car's power.
49081692_1623809001052723_84941082022694
Finally started pulling things out to do the head gasket. I feel like I have no idea what I'm doing :)
49204825_1623866184380338_17406201247396
49289630_1623866147713675_36956265871908
49090697_1623865967713693_44559515135917
49062818_1623866087713681_87169897232995
49022298_1623866114380345_15250335240573
49098351_1623866014380355_60947515744945
49048650_1623866067713683_79866242381926
49071723_1623865954380361_57476572026723
Bit more done.
49671255_1628006683966288_39359713980018
49205056_1628006740632949_16652123488366
49898890_1628006817299608_75910813725512
49143058_1628006917299598_54473029756576
49342392_1628006967299593_60968430431790
49841012_1628007003966256_82682553283746
Out of the comfort zone, down the garden path and out into the wilds...
49617508_1629146510518972_16605007310581
49864832_1629146560518967_56695226164576
49592409_1629146633852293_67795939324319
49589755_1629146720518951_93636171157995
49444814_1629146813852275_88829990526276
Eeeeeeeeee.......
Good luck!!
Id probably be stress puking for days if i even started giving serious thought to doing that kinda job on me own :D
10 minutes ago, mac11irl said:
Eeeeeeeeee.......
Good luck!!
Yeah it is rather stressful. Got a mate coming later to help with the downpipe bolts, I need arms about 2ft longer to get to the nut and bolt at the same time.
Head gaskets not too bad, do what you’re doing and take plenty of images. Bag and label smaller bits. Just take your time. Should be straight forward, all the best with it Rob.
If you don't mind a small piece of advice Rob, as B33fy said, take your time, take loads of piccies if you are not sure of the sequence.
Once you have the head off, spend some time once you have the head and block faces clean, checking them with a quality straight edge and some feeler gauges to see if you have any face distortion. A calm hour spent doing that could save a lot of disappointment later.
Also make sure you have a valid retorquing sequence to tighten up after the head is refitted, but it looks like you have a factory service manual in one of the piccies, so I guess you've got that one covered.
Good luck, and all looks good with what you have done so far............. just don't forget to breathe :giggle:.
Thanks. All advice is always appreciated. Got my mate booked to help with re-assembly. He's an ex-mechanic and knows his stuff.
He came round last night to help me with some rusty nuts that needed holding from the top and undoing from the bottom. :D
Getting there! Ran out of time, next step is to remove the head bolts. Gulp...
49949589_1640540216046268_80871799237870
49948303_1640540242712932_67565955679728
49898659_1640540206046269_13677998480021
50244545_1640540292712927_20022095746684
I guess I should get the turbo reconditioned while it's out :D
Edited by RobClubley
Best practice for removing head bolts is to release torque in the opposite order to how they're torqued up. Once you've done that a few bangs around the head with a mallet should release the gasket "stick", and only then start removing bolts!
Didn't need any bangs!
The head is out!
Almost all of the exhaust manifold studs were loose. I can't find any cracks in the exhaust manifold, which is good. It's pretty mucky and corroded inside.
Dropped the turbo off at Diesel and Turbo in Petone for them to check out.
49937611_1643019882464968_50131888383868
50574191_1643019912464965_51974140173704
50001271_1643019972464959_70826378354711
50103856_1643020039131619_64321021945304
50217969_1643020109131612_19205913190051
49949558_1643020182464938_63985921166577
49763000_1643020252464931_89987775669028
49731889_1643020302464926_89282490198770
49864657_1643020359131587_56389727717792
50466406_1643020405798249_81431423984661
50449623_1643020455798244_40255973410157
50095658_1643020525798237_34916090006114
When you clean the head and block faces up, you can face them off with a sheet of moderate wet and dry paper wrapped around a square flat object like a bit of 2"x2" timber that is big enough to run the entire width of the head and block faces.
Then run the entire length of the head in strokes like planeing a piece of wood to size. Try not to concentrate in one area as the can cause low spots and issues that you don't need.
Once it is clean, check it for low spots with a steel rule and a light behind it, any areas that you see light under the rule, pass a feeler blade under it using a bigger one each time to see how big the gap actually is, then see what the tolerance is for distortion on the faces, but ideally you dont want any low spots at all.
Well done mate, all done and no nervous twitches :biggrin:
Dropped the turbo off today at a local specialist for assessment, and the head and exhaust manifold to another one.
The manifold is warped and has been leaking quite a bit. Will get that machined. Waiting for assessment on the other stuff.
Head work that's being done:
49895945_1646541112112845_75214050415261
Assessment from Diesel and Turbo in Petone:
The exhaust housing has a few cracks but it will go again.
Turbine shaft has been rubbing on heat shield and bearing housing is eroded. We are trying to find some part to repair.
Well I'm not getting my torque wrench in there!
Bumper off next then. And work out how to get around the welded-in metal front panel.
50527390_1649093445190945_81213956948513
One for you Rob, taken yesterday at Brands Hatch..
That's a proper doggies gonads report there Rob, are they saying coolant loss is down to gasket failure, and just skimming the head for certainty or has a gallery breached to the outside world?.
You've dodged a bullet not having to do valve clearances though, they can be frustrating if you have contact wear inside the valve side of the follower on older cars, as you never get a consistent reading twice without sorting the follower issue. A good engineering shop just take that sort of stuff without even stopping to think in their stride.
As for the torque wrench access issue, can you release the engine mounts and lift the engine enough to use an 18" extension through any air vents in the valence?. What sort of torque setting have you got to use on the offending item?
Apparently if I remove the bumper I'll find a service hole. About to do that now.
The bolt requires 450Nm tightening torque!!
Bumper off, and it seems the internet is wrong about the crank bolt being 24mm. I don't have a bigger socket, so need to get one. Guessing 26 or 27mm.
Also I painted some bits.
50543039_1650682191698737_46114048870480
50234190_1650682165032073_67355166630530
50313592_1650682218365401_75396653741579
