Rob's Ur Quattro
5 hours ago, Paws4Thot said:
It would bug the H*11 out of me, not because the view doesn't do it, but because there is no sign of road workers to be protected!
I bet Rob could jump the lights too - looks plenty wide enough! 😇:thinking:
Edited by Gaz
felt like it
  • Replies 1.7k
  • Views 176.1k
  • Went to the supermarket while I waited for traffic to die down a bit. Second supermarket car park of the evening. Terrible pic, it was getting dark The drive home was uneventful. L
  • RobClubley
    RobClubley
    Back on its wheels at last!
  • Wento for a quick trip to the petrol station. Got sidetracked. I am loving this car! It sounds like it's gargling on the fuel not just drinking it, what an awesome sound!
Lol there were workers but the coned area was ridiculously long. I waited 20 mins at these lights on the way up.
After an hour of back-road driving therapy.
  • 2 months later...
6-monthly Warrant of Fitness didn't go so well...
Bit of tinkering today. Added to the job list. Sorted the rusty battery tray, fixed the light issues, found out that my aerial works, but I have no idea how to make it go back in. Started removing the door handles but with the battery removed I can’t put the windows up to get to the inside. So I spent some time trying to work out exactly where brake fluid is leaking from. Still working on that!
Wow that's a bit of a list
Proper winter jobs.
Very happy with these brand new door handles from EBay. Really solid and they fit perfectly
Tracking down my brake fluid leak and after degreasing and cleaning it all, at first I thought it was leaking from the odd one-way screw in the bottom of the brake servo, but looking at the photo it looked like it was between the servo and master cylinder.
Soo good news! The master cylinder is fine. Bad news! The servo is leaking hydraulic fluid.
And it’s out! As always, there was rust to clean up, and something not fitted correctly- the return spring in this case.
Not much has changed, I thought I tracked down a replacement ATE part that looks identical and was fitted to 80s inline-six E23 BMWs,  but when I ordered the part, the supplier's supplier couldn't find it in their warehouse !
So I went back to plan A and sent the old one to a bloke called Jay in California, who rebuilds them.
https://www.jaysbmwparts.com/contact
Meanwhile I got some oil and filters, it's due for a change anyway :)
Yay!
The story...
Brake booster, freshly rebuilt by Jay Stratton in California, and back to Taranaki in Aotearoa, via Oregon!
Brakes back together and working.
I sussed out my intermittent brake light issue. It seems the tail light insert eventually warps a bit over time and the metal tracks lift slightly from where they’re fixed with melted plastic tabs. There are brass leaves under the tracks which connect to the bulbs. The leaves rely on the tabs holding the metal in place to make contact. I added a screw to fix it. Then clicked why there’s already a screw, someone already fixed the same issue with the indicator.
Next day was the WoF
Failed, with a shorter list than last time. One indicator bulb had died, the belt to the hydraulic pump was cracking, and one headlight alignment isn’t right. The same headlight I spent ages sorting out for the last WoF!
Replaced the belt, need a new alternator belt too but they’re not available locally.
The top bolt on the alternator needed all of the swears to get undone.
Next day - WoF round 2. Everything was sorted but the WoF mechanic had gone home.
Finally day 3.
Got to the WoF place expecting just a quick check and sign-off and she said "The left tail light is too dim". FFS
The solution was to go to Supercheap and buy some Narva LED tail light globes, which don't seem to care that one tail light cluster is only getting 10 volts.
$132 for 4 tail/stop lights and 2 indicators (because why not make them all brighter?)
Finally the WoF was signed off.
WoF passed, just in time for the road trip event that weekend. I was really excited for that, but unfortunately non car-related issues prevented me from going.
7 minutes ago, RobClubley said:
I must remember this tactic, and have firemen on standby with that thing to cut the roof off.
The rain finally stopped today so I went for a Sunday drive
  • 5 weeks later...
Rather moist drive to Wellington and back a couple of weeks ago.
Rusty has been allowed back into the garage!
I was trying to work out what the strange bonnet mascot was in that last picture then realised it was a reflection of the garage door opener...
New high level brake light. The existing one always irritated me. It was cheap, and has faded and warped in the harsh New Zealand sun. Plus after it fell off the window due to useless sticky pads, I made improvised brackets from a bit of piano hinge I had laying round.
I noticed what appears to be oil leaking, over the down pipe, which would explain that burning smell I noticed!! Looks like maybe it’s steering hydraulic fluid as it’s on the firewall behind the reservoir. It would have to be coming out with a bit of pressure to get there. This clamp looks suspect, though looking back at pics it has been like that for some time. I’ve added a second clamp for now, let’s see what happens.
A second clamp seems to have sorted the power steering oil leak.
Looking good Rob 👌
