Fitting TTS Engine cover on TFSI Octavia vRS
Hi guys, I have had the Ram Air Oversize Induction kit fitted when I had my R-tech stage one map. (great piece of kit btw!)
Ive now bought a TTS engine cover, any advise as to how to fit the thing?
I think "Damo" on here fitted one to his vrs,the car is for sale on here at the moment & i think he did a project thread on here as well,that may include the fitting of the engine cover.  :thumbup:
Yes, I have fitted one on mine.
You need the cover, and 3 longer screws to replace your standard ones.
Parts Used were:
06F 103 925J Engine Cover
06E 103 164E Front lug
WHT 000 731A  Rear Lug (You need 2 of these)
I got all the bits from TPS, and it came in around £120 IIRC
Once you have the lugs, hold the cover over the engine and you'll see where the lugs that hold them are
Using a star key, remove your standard ones (They will loosen, then yank them as they have a rubber grommet on) and replace them with your new longer ones.
Then just push your cover down until it clicks on
Hope that helps :)
Ive got the same induction kit as you, i agree its a really good bit of kit, also got the TTS engine cover, tidies up the engine bay nicely .
The front lug screws into an empty hole in the inlet manifold, from there its pretty straight forward to identify which two lugs need to be swapped over.
Theres a picture on a golf forum with the locating lugs highlighted if you get really stuck.
  • 4 months later...
Hi guys. Can i just ask where you got that induction kit from? been looking for one a while now and that seems like a good choice.
BTW loving the engine cover
  • 4 weeks later...
Induction kit is from Ebay. Normally you can win the kit for less than its listed for using best offer.
Ram Air Oversize is what its called
  • 1 year later...
Anyone got a link for purchasing a TTS cover?
Many thanks in advance?
Welcome.
Maybe try
