Amunsen MIB1 Firmware
7 minutes ago, Lefa100 said:
Hi! I've been looking for a 0490 update for ages. Is there any chance I could get it via PM? Thanks!
I will send you a link in a few moments
  • Replies 982
  • Views 212.7k
  • I have updated my Amundsen from 0435 to a newer version which can be found on the net. I don't want to share the link here to avoid deletion but I will kindly PM it together with the instructions.
  • If you have instructions they'd be appreciated
  • Guys,   From now on a newer firmware is available for MIB1 Bolero/Amundsen. I have installed it without issues. Users previously contacted me: check your PMs. Others just contact me for the deta
Hello everyone,
I have been looking for a long time to download the latest software update for my Amundsen MIB1 system.
I have seen that many of you have the latest firmware. If someone could send it to me it would be very helpful !
Below is a screenshot of my current system:
4 minutes ago, JoLaDouille said:
Hello everyone,
Welcome, I can send link to you in a few moments
Edited by varooom
And it's working ! Thx @varooom ! :)
Ive tried searching everywhere firmware update for h44, current software version 0376 to try to resolve bluetooth quality issues but to no avail ;(
Can you show your software train so I can double check it.
Here :)
11 minutes ago, sebbz said:
Here :)
I am unpacking and repacking a file now, hopefully PM you in a bit with link
Wow amazing thank you!
It might not be compatible yet, but you can try it (it will reject if not correct/supported)
SupportedTrains = "MHIG_EU_VW_P0050*, MHIG_EU_VW_P0066*, MHIG_EU_VW_P0070*, MHIG_EU_VW_P0344*, MHIG_EU_VW_K0344*, MHIG_EU_VW_P1054*, MHIG_EU_VW_P1532*, MHIG_EU_VW_P1534*, MHIG_EU_VW_P1538*, MHIG_EU_VW_K1540*, MHIG_EU_VW_K1550*"
Hi Guys.
New to Skoda and the forum. I’ve acquired a used 2015 Octavia 3 (Greenline) Estate with mib 1 Amundsen. There appear to be no smart link or mirror link or CarPlay options from default menu. Is there anything I can do through updating that will introduce this functionality? I’d like to get into tinkering with this system but also appears to be no green testing mode (tried long push on menu button). Is this testing mode something I can switch on via OBDeleven (which I don’t have but am considering) or is it only an mib2 function? Incidentally my old basic OBD2 (elm) Wi-Fi dongle refuses to connect to ECU on this vehicle - is that something I should be concerned about? Finally I’ve attached a pic of my update status below - what improvement/added functionality is possible with the latest updates?
Thanks in advance for any help. Sorry to go on a bit. I’m just excited to be here!
Mark.
2 hours ago, SaintSkoda said:
Hi Guys.
Mark.
This is a job for @pab567 who will come along and suggest what can be done, it might be overall better to swap over to a MIB2 unit (which he can sell or suggest parts to buy)
Recommend you have your VIN ready to go, as that might be next question to answer.
To get SmartLink (Android Auto + MirrorLink + Apple CarPlay) you must have both glove box and display units exchanged. You can install one of four different glove box units:
- MIB2 Bolero
- MIB2 Amundsen
- MIB2 Columbus
- MIB2.5 Columbus
You also need to replace display unit:
- for MIB2 Bolero you can use either 6.5" model number 5E0919605H or 8" model number 5E0919605N
- for MIB2 Amundsen and MIB2 Columbus you can use listed above display as well as 6.5" model number 5E0919605J, 8" model number 5E0919606, 8" model number 5E0919605M
- for MIB2.5 Columbus the only display unit that works is 5E0919606D
If you would like to have also support for Apple CarPlay or better phone charging (current up to 1.5A comparing to 0.5A) then USB must be replaced as well.
The question is what is your budget and which of listed below features are "must have":
1. Video playback from DVD, USB, SD
2. CD playback
3. OEM navigation
4. displaying OEM maps na Virtual Cluster (Active Info Display).
Thanks pab567.
Sounds like mib 1 is limited to what I have at the moment.
To be honest, video or cd playback not that important  to me.
I would have liked to have kept OEM maps and associated in-instrument directions but I think I may well sacrifice this in favour of one of the cheap Android based 10” displays that will retain the car menu options whilst providing onboard Nav apps, phone menu, DAB etc etc. I think a solution like that gives me the Carplay access I want, a large hi-res screen and all for less than £200. I’m guessing that upgrading to mib 2 with a larger display is going to cost 2 or 3 times that?
hello everyone, i have amudsen 1
5e0035874a with soft version 0435 and hard version 041. Can you please upload the latest version. thanks
I will send you update for your car
Hi to all, as i seem to be in the "same boar" (Sw 0435) , could someone send me a link for the latest version (0490??)
Thanks in advance
Thanks in advance
Yes I can send you update
Please can send me anyone the newest firmware for Infotainmentsystem! Thank you!
You should hold down your Menu key for 10 seconds to find your Software Train value and post back.
Installierte SW Train Version: MHI2_ER_SKG11_P2104_1
SW MU Version: 0318
Teilenummer: 3V0035020B
Software-Version: H25.14.38_HIGH2_EU
Thank You for Support.
SW MU Version: 0318
I have sent  you an update via PM
Are you still supplying the update @varooom?
my partnumber is 5E0035864A
Hardware 040
software 0435
sw train MSTD_EU_SK_P3420
SW MU 0435
Hardware 040
software 0435
SW MU 0435
Yes, it will be in PM shortly
Hi varoom,
i'm interested in the update for my MIB 1 Amundsen unit as well.
hardware 040
software 421
Thank you in advance!
