Fabia III front grill removal
Guys,
Yesterday I've picked up this beauty - Fabia 1.4 TDI 90 hp + DSG7.
Do you have any idea how to remove the front grill? I want to put black foil on it. I've unscrewed the top 4 nuts and after that I am stuck.
Is there an easy way or it is pain in the ***?
More info:
It has the local trim level "Edition" - Sports Seats + Heating, Tinted Windows, Bolero Radio, PDC, Auto Headlights + Wipers, Two colour concept + black wheels, KESSY, LEDs, etc.
Paid 13500 GBP at today's exchange rate
 i have done the bottom grill  only ,   that needed  a thin plastic trim tool long wedge   between it and the bumper  , push in and down gentley but firmly and pull grill  outwards gentley  all around
( its tabbed every 3 inches or so all round )
its a massive pain to do it .
 i think the top grill is the same once you open the 4  screws ,  you need a thin trim tool , between it and the silver surround ,  or between the silver surround and the bumper
 and it has loads of clips so BE VERY CAREFEUL !
the silver sorouund is tabbed in  to the bumper and the black grill and the clips are crappy brittle  plastic   so be gentle as a lamb on it , ie be careful then back off even more ;)
the silver bit would be the same as this black bit ,  and would have a billion tabs
and read this
http://www.briskoda.net/forums/topic/203496-monte-carlo-grill-mod-fitted/page-2
Edited by dadumtish
It is a single piece grill with only lower part. The hardest part is to remove the grill from the bumper. I have unbolted the top four screws which are visible and after that I am stuck. But I will try following your guide!
Thanks again. I will post pics if it is sucessful! :)
Sent from my SM-G900F using Tapatalk
Unfortunatelly no luck...If I can see some actual pictures it would be great.
Why not lay black foil over the whole grille, smooth down and then trim around the edge with a sharp knife?
This is last idea. But I am not quite sure if it would turn out good with all those sharp edges etc.
