Kellaway's Fabia VRS
Very nice attention to detail :)
Lovely feeling getting rid of rattles ain't it!!! :D
  • Replies 149
  • Views 27.4k
  • Well it rained last night. Looks like the Gtechniq C2 - Liquid Crystal v3 did a cracking job! Look at these beeeeeds!
  • Moved on to the other side and luckily its much easier, had the strut out in about 15mins. IMG_7379.jpg by Daniel Kellaway, on Flickr IMG_7380.jpg by Daniel Kellaway, on Flickr IMG_7381.jpg by D
  • So the car has gone from this. IMG_6404.jpg by Daniel Kellaway, on Flickr To this, IMG_7468.jpg by Daniel Kellaway, on Flickr IMG_7470.jpg by Daniel Kellaway, on Flickr The handling has
Great work! Are you from Darlington?
Richmond, just down the road.
Little update for today.
So i nipped down to Mansfield to collect some parts off Jamiekirk95. Came away with some used VRS mats and a big box of new suspension goodies.
Gave the mats a good scrubb with APC and a good hoover.
27528765122_6352ffc76c_b.jpgIMG_7313.jpg by Daniel Kellaway, on Flickr
27594222056_b582ceeaf8_b.jpgIMG_7319.jpg by Daniel Kellaway, on Flickr
Old,
27019084673_003b8cf060_b.jpgIMG_7321.jpg by Daniel Kellaway, on Flickr
27594232626_e2ac107fdb_b.jpgIMG_7322.jpg by Daniel Kellaway, on Flickr
New. Looking way better! Excuse the interior it needs a bloody good clean! Job for the weekend if the weather stays nice.
27528789292_d897a3da83_b.jpgIMG_7325.jpg by Daniel Kellaway, on Flickr
27594242416_4139bf02e3_b.jpgIMG_7327.jpg by Daniel Kellaway, on Flickr
The big box of new suspension parts, Top mounts and bearings, bump stops, HD droplinks, shock covers. Just got to order some new shock's for the front and a few other bits of bobs and going to refresh the front suspension.
27350580530_ddafa2530a_b.jpgIMG_7315.jpg by Daniel Kellaway, on Flickr
Love this, not sure why I was unsubscribed to this, it was showing in my participated section on Tapatalk lol, keep it coming
Sent from my SM-G920F using Tapatalk
So with the arrival of another new tool.
27104249693_1eec49a440_b.jpgIMG_7336.jpg by Daniel Kellaway, on Flickr
I decied to get cracking on changing the front struts and top mounts etc.
Old.
27680650976_cc6354ef25_b.jpgIMG_7338.jpg by Daniel Kellaway, on Flickr
27714624825_7a8a5dcc4f_b.jpgIMG_7342.jpg by Daniel Kellaway, on Flickr
Lower pinch bolts looked friendly ;/
27436454520_e904daa40c_b.jpgIMG_7344.jpg by Daniel Kellaway, on Flickr
I started first with the drivers side as this side is ment to be the hardest due to the drive shaft fowling the sub frame.
With some back and forth motion and lots of WD and a large hammer, the bolt removed.
Old v New
27639993841_c7413e8eb3_b.jpgIMG_7347.jpg by Daniel Kellaway, on Flickr
Whipped the vac controller off.
27102402794_405804380c_b.jpgIMG_7349.jpg by Daniel Kellaway, on Flickr
27680673006_acece7889a_b.jpgIMG_7350.jpg by Daniel Kellaway, on Flickr
Used the strut splitter tool to open up the hub then hammered it down as far as it would go, do to the drive shafts the only way to get the strut out is use spring compressors.
27640001911_0d1912ede8_b.jpgIMG_7353.jpg by Daniel Kellaway, on Flickr
Once the strut was removed from the hub, i had a nightmare as one of the captive nuts that hold the top mount on decided to break off..
Cue about half an hour with the mole grips and lots of swearing!
27102407274_9f51fdba95_b.jpgIMG_7351.jpg by Daniel Kellaway, on Flickr
27102409564_dbd5bb1ebb_b.jpgIMG_7352.jpg by Daniel Kellaway, on Flickr
Where the captive nut should have been.
27680685326_9052e1397c_b.jpgIMG_7355.jpg by Daniel Kellaway, on Flickr
After a bit more swearing, i have a prize!
27680688116_0eae1a6bbe_b.jpgIMG_7358.jpg by Daniel Kellaway, on Flickr
The broken off captive nut and the very worse for wear top mount bearings.
27102419384_c46ed655ba_b.jpgIMG_7359.jpg by Daniel Kellaway, on Flickr
27104290253_3d8dc49f87_b.jpgIMG_7361.jpg by Daniel Kellaway, on Flickr
Got it mounted up in my 1 ton spring compressor. Your a braver man than me if you use the cheap Chinese handheld ones to change springs/struts.
27640010601_f055b595bd_b.jpgIMG_7362.jpg by Daniel Kellaway, on Flickr
No mucking about, big ass impact to take the top nut off.
27680705076_117ab12ba4_b.jpgIMG_7363.jpg by Daniel Kellaway, on Flickr
Top mount
27714672915_11315f2d25_b.jpgIMG_7364.jpg by Daniel Kellaway, on Flickr
Pulling apart.
27714677385_c573723863_b.jpgIMG_7366.jpg by Daniel Kellaway, on Flickr
27104300113_934839c435_b.jpgIMG_7367.jpg by Daniel Kellaway, on Flickr
OLD V New, both compress and left to expand. This might be the reason for my questionable handling! New is Bilstein B4 Struts.
27680719506_b21a255120_b.jpgIMG_7368.jpg by Daniel Kellaway, on Flickr
Rebuild back up with new Top mounts, Bearings, Bumpstops and dust covers.
27104307343_b31385c20f_b.jpgIMG_7369.jpg by Daniel Kellaway, on Flickr
Top mounting bolts cleaned up.
27640026051_ec79f99e40_b.jpgIMG_7373.jpg by Daniel Kellaway, on Flickr
Big old space.
27104314323_a818eba499_b.jpgIMG_7374.jpg by Daniel Kellaway, on Flickr
Re installation was fun....
27640032481_189d8e80d8_b.jpgIMG_7375.jpg by Daniel Kellaway, on Flickr
27680731356_b98efb2408_b.jpgIMG_7376.jpg by Daniel Kellaway, on Flickr
A combination of floor jacks, spring compressors and pure luck we got it back installed.
While the arch liner was out, gave it a quick clean. Not as clean as i would have liked but i was time limited.
27680736376_927e25f3a3_b.jpgIMG_7377.jpg by Daniel Kellaway, on Flickr
27104332693_797a4447ba_b.jpgIMG_7378.jpg by Daniel Kellaway, on Flickr
Put the arch liner back in with new fasteners.
27104336363_f3f744a406_b.jpgIMG_7379.jpg by Daniel Kellaway, on Flickr
27613979832_5202f050ba_b.jpgIMG_7380.jpg by Daniel Kellaway, on Flickr
27613981952_63dd33a132_b.jpgIMG_7381.jpg by Daniel Kellaway, on Flickr
27680756586_2b215a4036_b.jpgIMG_7382.jpg by Daniel Kellaway, on Flickr
27714705995_e41c3b0aa3_b.jpgIMG_7383.jpg by Daniel Kellaway, on Flickr
Yummy
27640045141_1b2c3b36cc_b.jpgIMG_7385.jpg by Daniel Kellaway, on Flickr
Same again, this side didn't want to expand.
27102466214_2b79aedd76_b.jpgIMG_7387.jpg by Daniel Kellaway, on Flickr
Fully rebuilt.
27680773336_5c7b214348_b.jpgIMG_7389.jpg by Daniel Kellaway, on Flickr
15 minutes later and it was back in, much faster..
With the struts installed i changed the drop links to the Meyle Heavy-Duty ones.
27680778346_f8346f7826_b.jpgIMG_7390.jpg by Daniel Kellaway, on Flickr
27104361693_2a25457f93_b.jpgIMG_7391.jpg by Daniel Kellaway, on Flickr
27436517260_a119cac1c4_b.jpgIMG_7395.jpg by Daniel Kellaway, on Flickr
The finshed artical.
27102477194_9417c10885_b.jpgIMG_7392.jpg by Daniel Kellaway, on Flickr
Not as clean as i like but had run out of time and needed the car back on the road!
Went for a test drive and wow the handling is transformed, well worth the time/effort/money!
Seems every update is a good detailed one!
will be worth changing the rears also if they are original like those fronts!
Nice work. Ive never used a spring compressor [emoji23] just impact gun to buzz off nut and stand onvthe strut. Move your hand out the way as it pops off [emoji15]
You trollin?!
How do you get the spring back on then? :D
You trollin?!
Never fitted standard springs [emoji23]
Took them off to use top mounts on coilovers several times.
All ready changed for new genuine. ;)
Your a braver man than me. Ive diced death too many times with handheld spring compressors! Best £100 spent ever on that strut compressor, so much faster and safter!
Well I've been loving the new suspension setup so far, how ever the arch gap was bothering me.
Just by chance i came across a set of H&R 35mm Lowering Springs on Ebay that had about 2500 miles on them. Though i better call my insurance before bidding on them and see how much to add them to my policy, they wanted a grand total of Nill! Well Chuffed not even an admin fee!
So set up a sniper on Ebay and to my delight i won the auction at a steal of £67 :D
Pics from advert
27861255885_734d78fd3e_b.jpg$_57 by Daniel Kellaway, on Flickr
27861269785_6a0091a20d_b.jpg$_57 (1) by Daniel Kellaway, on Flickr
Just awaiting delivery now, and then hopefully next week will get the suspension pulled apart again and them installed :D
I'd be interested to see how comfy / bouncy the side is with the B4 dampers and those springs. I bought B4's for my old Ibiza FR that i never got to fit. I was considering fitting them to my Fabia (just now it's Eibach Pro Streets) but i read somewhere they're a bit softer than standard Fabia ones because they were only replacements for the lower spec, non sport models.
Im really liking the B4. Not bouncy at all with standard springs. Just need to loose the hight. Going to be cutting down the bump stops to hopefully wont bounce to hard!
Cutting down your bump stops? Why?
The only thing that will achieve will be nice knackered Bisteins when they bottom out :(
Also as above,if you look on the Bilstein website they don't list B4's for a VRS,I wanted some for my Mrs SE so looked into it.
I was told by a supplier on here they are too long for a VRS as they are for standard Fabias.
Will be cutting the rears down not the front. They are not b4 but new genuine oem, and from what ive been reading its adviced to trim the rears. Im going to see how i get on running the B4 on the front lowered. One thing for sure they are a hell of a improvment over my old nackard oem thats for sure.
H&R 30mm Super Sport Lowering Springs Installation.
So i won these on Ebay for an absolute steal, seam to be really recommended by a lot of people and since the VRS was looking like a monster truck i jumped on the opportunity!
27985989975_b73d6f0a9c_b.jpgIMG_7396.jpg by Daniel Kellaway, on Flickr
27372123013_7fd3a224c0_b.jpgIMG_7399.jpg by Daniel Kellaway, on Flickr.
Got some new rear spring seats and rubber mounts as well as some lemforder rear top mounts to go on.
27706157560_4401fccf0d_b.jpgIMG_7404.jpg by Daniel Kellaway, on Flickr
So got the car in the garage.
27372815384_d4f8ac013b_b.jpgIMG_7408.jpg by Daniel Kellaway, on Flickr
27951516576_23b924005e_b.jpgIMG_7414.jpg by Daniel Kellaway, on Flickr
Rear arches both removed.
27372134433_f264c9ee19_b.jpgIMG_7415.jpg by Daniel Kellaway, on Flickr
27706178630_19314cb1a6_b.jpgIMG_7416.jpg by Daniel Kellaway, on Flickr
Lower strut bolts still looking nice and new, buzzed right off with the impact.
27372829444_e66a68d81e_b.jpgIMG_7417.jpg by Daniel Kellaway, on Flickr
Shocks out.
27908182251_561959e5c2_b.jpgIMG_7419.jpg by Daniel Kellaway, on Flickr
Changing over the top mounts and trimming the rear bump stops.
27372835984_75fc853742_b.jpgIMG_7421.jpg by Daniel Kellaway, on Flickr
New v Old
27706190080_078fb59f3c_b.jpgIMG_7422.jpg by Daniel Kellaway, on Flickr
Removing 20mm
27706193070_4169740c37_b.jpgIMG_7424.jpg by Daniel Kellaway, on Flickr
27951532006_c31fc3dcaa_b.jpgIMG_7425.jpg by Daniel Kellaway, on Flickr
Re-assembled
27908198451_89c7a286ee_b.jpgIMG_7427.jpg by Daniel Kellaway, on Flickr
27908202911_b9eb80382f_b.jpgIMG_7428.jpg by Daniel Kellaway, on Flickr
Got the pry bars out and removed the old rear springs.
27372171883_e1879d3fb5_b.jpgIMG_7431.jpg by Daniel Kellaway, on Flickr
Lower spring seat, has seen better days haha!
27706209120_6f99ea8941_b.jpgIMG_7432.jpg by Daniel Kellaway, on Flickr
27706232750_75d2cfa620_b.jpgIMG_7437.jpg by Daniel Kellaway, on Flickr
New v Old
27883991052_b2d0d7538b_b.jpgIMG_7434.jpg by Daniel Kellaway, on Flickr
The spring cups where in need of a clean up so, i did the usual - wire wheel, krust, primer then top coat.
27372875444_b4bd973191_b.jpgIMG_7436.jpg by Daniel Kellaway, on Flickr
27951595836_9da9b2c2c5_b.jpgIMG_7442.jpg by Daniel Kellaway, on Flickr
27372895474_74fd4b5a5f_b.jpgIMG_7448.jpg by Daniel Kellaway, on Flickr
Finally with the new spring seats installed.
27372229063_bf4fd38d04_b.jpgIMG_7450.jpg by Daniel Kellaway, on Flickr
Quick attack with the pry bar and t springs where installed.
27706256070_ea01414938_b.jpgIMG_7451.jpg by Daniel Kellaway, on Flickr
Shock back in
27951822386_c71e79540c_b.jpgIMG_7452.jpg by Daniel Kellaway, on Flickr
27706546140_f861c9344f_b.jpgIMG_7454.jpg by Daniel Kellaway, on Flickr
All back together.
27372451893_e6295e4f67_b.jpgIMG_7455.jpg by Daniel Kellaway, on Flickr
Got the wheels back on and spun the car around, pulled the fronts off. Not going to go into much detail as just changed these before.
27884282992_ff3ebc72aa_b.jpgIMG_7463.jpg by Daniel Kellaway, on Flickr
Getting rebuilt
27951834536_cd7dc62ba1_b.jpgIMG_7464.jpg by Daniel Kellaway, on Flickr
Both sides installed.
27908519111_cae1f40c43_b.jpgIMG_7467.jpg by Daniel Kellaway, on Flickr
Went a lot quicker than the other day, both sides sorted in about 2 hours.
Sits lovely now :)
How the VRS should have been standard imo.
Word of warning,you are not meant to jack the car up in the middle of the rear beam.
There is a warning sticker on them from new ,but they are missing now on some cars due to the age.
Sits lovely now :)
Cheers mate. i didnt jack it up on the rear beam, was used to support the beam while i took the shocks off :) Think my sticker on my beam is long gone!
Ah right :)
I wondered what that piece of corroded metal at the base of tge spring was when changed some few weeks ago!!!
Looks lovely, spotted you parked outside the cop shop this afternoon, very tidy.
